I've been getting fuel cuts recently, first soft now hard. Have IE HPFP, 155 bar PRV.
From logs:
A) The good
--Low fuel pressure OK
--Battery voltage / alternator duty OK
--Great rail pressure tracking until fuel cut
--Relief valve works properly
--Cam follower visually confirmed good
--Brand new LPFP filter
--Brand new rail relief valve
B) The bad
--HPFP rail actual drops below requested, bottoming out somewhere in the double digits.
The car drives normally until put under moderate to heavy load and then actual rail pressure will dive from requested, now resulting in a hard fuel cut with throttle plate closing. Rail pressure will recover if the driver lets off and requests a low (stock) load. I suspect bad a N276.
Planning to buy a brand new HPFP w/ N276 and swap my IE internals. Good plan or should I consider something else?
From logs:
A) The good
B) The bad
