Nikerey
Darkness
- Baton Rouge
I just sent the GTI back to VW at the end of its lease so I have a number of parts I pulled off or had laying around.
All parts are from a 2006 GTI FSI DSG unless otherwise stated.
Strong emphasis on the OBO. Its either getting sold or going in the trash. Any offers that arn't worth me going to UPS wont be accepted so try to not lowball.
Let the fun begin.
R32 Bumper Reflectors -$30 obo
These are the reflectors that sit in the lower portion of the R32 rear end. These have been smoked with tint spray. If I remember correctly were only installed once but never actually on the car.
Edition 30 E-Brake - SOLD
The E-brake handle from the Edition 30. Red Stiching, easy install.
Euro Switch - SOLD
It turns your lights on
Valve Stems SOLD
VW GTI Valve Stem Caps
Gauge Rings - $10 obo
Silver gauges rings for new south gauges. Should fit other gauges of the same size, made of metal. Only 1 left
Center Air Vent - $40 obo
The stock center air vent.
Cup Holder - $25 obo
It holds cups
Intake parts - $30 obo
The part on the left is the inlet snorkel the attaches to the front grill and goes to the stock engine cover/intake. The part on the right goes from the engine cover/intake to the turbo.
Intercooler Pipes - $50 obo
The stock intercooler pipes. These were taken off when installing the Twintercooler and havent left the bag since.
DSG Shifter - $100 obo
The stock DSG shifter,
Wheel bolts - SOLD
These are the stock wheel bolts and key. As you can see they have a bit of rust on them, but just need to be cleaned up.
DV Valve - $35 obo
This is a revision C valve. If I remember correctly this was replaced under warranty and then I took it off for the Forge valve within a 1000 miles or so.
Side Mirror Turn Signals - SOLD
The stock side mirror turn signals
Stock Brake Pads - $20
Im not even sure why I kept these but these were replaced with the Hawk pads. If you need better shots of whats left let me know, I didnt want to pull them out of the box because they were crazy dirty.
Stock Fuel Pump - $75
This is the stock fuel pump, good to send in as a core for the APR fuel pump upgrade (they still do that right?) As soon as it was removed from the car it was put in the bag and then into the box. Since then its never been removed, thus why its still in the bag.
Wheel Bolts - $10
Im not sure why I have these, or why there are only 9 of them, but here they are. Size info on the tag in the 2nd pic.
Things I dont have pics of. If you want pics let me know.
Stock lower bumper - $50 obo
This is the unpainted lower section, swapped mine with the R32
Sways - $50 obo
Stock sway bars front and rear, no bolts, just the bars and brackets
Down Pipe - $50 obo
Stock down pipe
Rays Valve Caps - $10 obo
Valve caps from my Rays wheels. Metal with an etched Rays logo.
Let the fun begin.
Euro Switch - SOLD
Valve Stems SOLD
It holds cups
Wheel bolts - SOLD
DV Valve - $35 obo
Wheel Bolts - $10
Sways - $50 obo
Down Pipe - $50 obo
Stock down pipe
