nearsite00
So I did a search in the forum already and it seems most people with two aftermarket sway bars, typically have a bigger front (26-28) and a smaller rear (22-26) with the front on 'Soft' and the 'Rear' on Medium/Hard. I understand this is to make the car feel more 'neutral' when turning/cornering.
I haven't seen any threads of anyone's setup for front and rear sway bars that are the same size.
So for the Whiteline sway bars which I purchased, the FSB is 4 point adjustable and the RSB is 3 point adjustable.
http://www.autoanything.com/suspension-systems/61A6663A0A0.aspx.
Question for you tuning experts, what setting would you recommend for a little bit better cornering, with some understeer remaining. My car is stock other than the DG springs which will go on the car at the same time as the sway bars. I want to be able to tell the tuner to dial it in and I don't want to think about it.:iono:
