Faceman
Autocross Newbie
- Long Island
- '17 GSW 4Mo
FYI, if the rear of the driver is sitting flush against the inside of the cabinet, you can overheat the voice coil, as the pole vent is being blocked.
Great, thanks man. So just to ensure I'm on the right page as I haven't gone and physically measured the trunk yet:
- The box itself can only be 4" tall OD. At 4" tall, the floor sits flush and the box rests atop the spare tire.
- This leaves either 3 1/2" or 3 1/4" of mountable depth for the sub, depending on if going with 3/4" or 1/2" material.
- Any additional mounting depth necessary will have to be found by raising the sub off the box with flanges, causing the sub to protrude into the spare tire void. As long as the outside diameter of the sub is not greater than the inside diameter of the spare tire, this should work fine. However, I'd imagine care must be taken to ensure the sub has enough room to"move" (flex? whatever the audio term would be) and doesn't bump against the trunk floor.
Is that all about right? Looking to draw up some plans for a box build this weekend with my dad. Thanks guys!
*Edit - for reference, this is the sub I'm looking at
https://www.crutchfield.com/p_13692...CbF_Es6yrzSDZkDKoPnKNF1sK5Kf5FnsaAikTEALw_wcB
top-mount depth: 4-5/8"
sealed box volume: 0.65 cubic feet
Everything seems right on. I'm not sure what you mean by "bump against the trunk floor" but it is totally fine for the deck cover to lay right on the sub box. Maybe if you use flimsy 1/2" materials the box could flex and cause buzzing or other noise, but good materials and/or internal bracing should eliminate that.
If you meant the base of the speaker hitting the inside of the box, like others said, allow for some space/gap there - I think I have about 1/4-3/8" gap and I used a router to remove material there.
You're using your own amp right? The stock sub is dual voice coil so it has 2 sets of wires going into it.
A low excursion driver such as this one could get away with a half inch, but generally 1"+ is recommended.Didn't even think of that, thanks! Is there a rule of thumb for space needed to prevent overheating?
I went ahead and bought the VW plug (QTY 1 - 8E0-972-714) and VW wires (QTY 2 - 000-979-226-EA) to use the existing plug for quick/clean/easy removal, but you could certainly just cut/splice.
You need 2 sets of connectors for the box since you're running 2 pairs of wires into the speaker.
two repair wire are required which will be cut.
very kewl, good job. You might be able to find a box already made. So far only box I could find are around 5 inches in height, i believe that is too big?
https://www.amazon.com/Atrend-10SME-Shallow-Subwoofer-Enclosure/dp/B0016JKOZA?th=1
1) 1/2" would be fine for the sides as they're shorter spans. It's the larger pieces, such as the top and bottom, that need either bracing(best) or thicker material(good).WHAT I'D DO DIFFERENTLY
1) I'd use 1/2" MDF or 1/2" plywood for the top and bottom and brace the inside (still would use 3/4" for the sides). 3/4" MDF feels like overkill for a box this small and is pretty heavy.
2) If using 1/2" materials, I would've added a 1/2" tall flange to raise the speaker up to avoid needing to router the base.
Use mdf, and most defiantly hog it out behind the magnet. These subs the fit in that area don't bang hard enough to cause damage to the box, you could hog .25 out from behind the sub. Just brace itThanks for bringing this to our attention. Nice work! This looks like a great mod.
Only downside is the lost space of having to have floor raised to higher position. Will use connector so I can throw my standard sub in if I’m going to airport with bags and need the extra space. However, considering I did not even know there were two positions for hatch floor for first year of ownership likely I can live with the reduced space.
Saw this last night and since have finished my design, ordered parts and cut out box, will screw and glue tomorrow. $155 all in.
Used the same Rockford Fosgate R2SD2 speaker. My enclosure is 22”X20”X4” using ½” plywood, which is .7 cubic feet as recommended by speaker manufacture. With ½” plywood will have a .1” of clearance between driver and cabinet without routering or raising speaker edge. After hearing the input about heating concerns, will make sure the pole vent is clear and will consider routering to get some additional space. However, if I have some clearance I am not going to be too concerned.
