Replaced my friends cam follower
Cam didn’t look gouged too bad. No CEL, no fuel related codes. I would think there would be codes if the HPFP was damaged?
Car dies when dropping to idle after a pull. Replaced thrust sensor, n80. Checking DV tomorrow. Car idles rougher when dip stick is pulled, so I think PCV is ok. Only code is 001670- for Intermittent ECM relays short to ground. Can I rule out HPFP damage if there’s no codes?
