eurocars
5/17/15 - Never forget
- Indianapolis
- Ride
- 2006 GTI
Got it started tonight, fired up first try which I was amazed with. Video won’t upload with sound so I’ll get another one tomorrow
Pictured as a black and white scene from Young Frankenstein, "Its alive, Its Alive!"So after i got it started and running, i noticed something wasn’t quite right. It ran decent but sounded like a Subaru. Got to troubleshooting and found out that i had swapped injector #1/2 wiring at the bulkhead connector. They were both firing, just at the wrong times. Swapped pins and runs much better now.
Had a small coolant leak at one of the turbo supply lines but that is fixed, and there is a tiny amount of oil seepage from the engine girdle plate. I ALMOST gasketed it when i pulled the oil pan to seal it but thought it would be fine. Engine will need to come out to seal it back up, but it’s such a small leak I’m going to try and put some miles on it to work out the other kinks before i pull it again
