ErBall's Thunderbunny Build log
LilRaverBoi
Optometrist Prime
Cedar Rapids, IA
The IE and other aftermarket intakes look SOOOOO much better than the OEM plastic BS one. I really wish VW had sprung for something a little nicer. Very nice upgrades!
emanyankee
Louisville, KY
mk5 Gti
Back from the dead bump.
Recently moved and had a baby, so car stuffs been on the back burner. Any who got a solid deal on the following and couldn't say no. Brakes need refinished and the manifold has a few blemishes.
is this the 4 pot on the stock size rotor? looks like the ones i grabbed too
Das Gespenst
Glen Ellyn
That's the same brakes I have! Still have to finish prepping mine for paint and order up new rotors and pads. You should check out cquence for the rotors, basically OEM rotors that they drill, dimple, or slot depending on how you order them. Best bang for the buck on rotors imo.
ErBall
Measurement Mogul
Indiana
MQB A3
These rotors are stoptechs and are basically new.
I wouldn't buy any other rotors for these unless they're two piece.
xSabretoothx
Fast w/ training wheels
Raleigh, NC
2008 GTI
What tune are you going to run for the manifold?
xSabretoothx
Raleigh, NC
2008 GTI
Awesome! And you are going to run direct port meth?
ErBall
Measurement Mogul
Indiana
MQB A3
Had little to no time to work on the car recently, but did spend a few evenings refinishing the calipers. They're far from perfect, but they'll stop the car and match the rears.
ErBall
Measurement Mogul
Indiana
MQB A3
Sometimes I get lucky.
Threw on the brakes. Huffs needed 13mm spacer to fit, Audi wheels fit without. Going to buy tires this weekend. Still have to swap out the oil pan. Old drain bung was leaking had a new one and a new bung welded on. Hopefully I'll get a chance to go out and run some logs this weekend.
ErBall
Measurement Mogul
Indiana
MQB A3
Took a trip to tire rack this weekend. Bought some v12 evos. Also got the wheels and brakes on this weekend.
Also swapped out my old pan and a new oil drain line. It poured all day today, so I wasn't able to get out and actually drive this weekend.
