Sleep7R
- California
- 2019 Golf R DSG
You need to code out TC and starting vibration/rough road which ever you have or both to launch the car without interference, or just pull the ABS fuse to test.I mainly want it to remove the torque limiter.
Right now during launch, my car is cutting power, which results in 0-60 times around the same as stock. My 60 ft is really suffering (1.98 stock vs 2.08 at Stage 1). It's really annoying and I can't really feel the Stage 1 tune's power outside of freeway pulls.
Also switched to Shell. I'm noticing more power, but still some knocking going on (albeit less than with Chevron), mainly in the lower RPMs and gradually decreasing at high RPMs.
https://datazap.me/u/mbgolf7r/shell-1?log=0&data=8-11-19-20-21-22
https://datazap.me/u/mbgolf7r/shell-2?log=0&data=8-11-19-20-21-22
Oh, I was looking into that.You need to code out TC and starting vibration/rough road which ever you have or both to launch the car without interference, or just pull the ABS fuse to test.
Since I just got mine, I think I can weigh in. They shipped my order on the 3rd business day, which was a Friday. It arrived on Monday.What's the current wait time if an order is placed for an accessport with EQT staged tune?
when is the next sale?
They told me Seafoam should work just as well to reduce knock. I haven't tried it yet, though.Do you guys think a good quality octane booster will achieve the same results in reference to reducing or eliminating knock as well as E85 does? E85 is not available anywhere near me.
I do not know if there is a fix yet for the newer models with the car cutting power. As I understand you can disable certain things like rough road /starting vibration, but it’s not a 100% solution on some 2018s and all 2019s plus as it was in prior years. Hopefully something comes down the pipeline soonSo Aaron from EQT suggested I put a gallon or two of E85 in a tank to offset the Chevron 91. Zero knock!
Also here's a datalog from a launch. You can see timing bouncing around at the start and torque dropping when I let off the brakes. I think this is resulting in really poor (4.5-4.8 seconds) 0-60's compared to stock, and I can feel the engine cutting power even with ESC off and vibration disabled.
https://datazap.me/u/mbgolf7r/shell-91-e85?log=0&data=8-11-15-19-20-21-22-37&zoom=95-400
Hopefully DSG tune will solve this.
Man, if I'm still slower than stock even after the DSG tune, I'm giving up on this car, lol.I do not know if there is a fix yet for the newer models with the car cutting power. As I understand you can disable certain things like rough road /starting vibration, but it’s not a 100% solution on some 2018s and all 2019s plus as it was in prior years. Hopefully something comes down the pipeline soon
Already talked to them and I'm getting dyno tuned by them once my IE intercooler arrives. Already have the AMS downpipe sitting in my living room.Get this. The stg 2 with the big E
