ghost_03
- Syracuse, NY
Back with some more updates after almost 2 months with the car as a 6 spd! Everything is still working well and I am thoroughly enjoying the car. The clutch is pretty well broken in now too. Here's a few pictures of some details I took care of a while ago but haven't had a chance to post until now:
First, some more details on the retrofit harness I made. I wired up the reverse sensor and clutch sensor, which needed a variety of connections to power, ground, the ecu, and the vehicle control module, all referenced from the Bentley manual (the mass of highlighted pages spread out on my floor near the beginning of the thread). I approximated the wire lengths in the car before figuring out the best way to keep most of them together, then cut to length and crimp connected everything in (didn't want to solder anything in the hot engine bay). The wires are then wrapped in the plastic corrugated material, which is held down with white zip ties as seen in the photo. Black zip ties would've looked more OEM I think--I did white on purpose for contrast so I would know where to look if there were any issues. The red wire was then wrapped with OEM tape to the harness part it goes along.
There was a part in etka--crash support beam or something--that I noticed was manual only. I ordered that and from pictures and the repair manual assumed that it went under the dash somewhere to reinforce the clutch pedal in the event of a collision. I found where it seems to fit nicely and after install it looks like this--the black tube/wire bit. If anybody happens to know if their manual car has one that looks similar that info would be appreciated.
Also fixed the leaky hub flange seal. Here's where it went, you can see from the dampness it was leaking alright--some small drips on the floor but no puddles. I had topped it off too and fortunately it did not need much. It's the left flange--I wonder if the junkyard r&r'd the flange it to drop the trans from the donor car and in the process some of the sealing was lost.
And here's what goes in the seal:
Also not shown is the noise insulation piece that goes around the shift lever, can't seem to find that picture but that's a pretty standard part.
Next up is writing a new tune--I think I'm going to shoot for ~290hp with lower torque (say, 270 ft lbs), linear except for a smooth ramp up from the surge line. Basically chiseling the peaky torque to be more even and reducing overall power by 5% or so. I expect the car will feel a bit slower without actually being too much slower, and will hopefully make the oem clutch last a little longer and make the car a little easier to modulate for track days. But more importantly--it's something for me to tinker with!
