Chumleepro3
Baller on a budget
- Canada, eh?
- 2007 GTI
Ok, so after much searching I haven't found a direct answer. My car is stage 1 with Unitronic and I would like to put a downpipe on without going stage 2. Reason why is because I don't want the extra power!!...and extra wear and tear. I also don't want to have to buy a HPFP if I get fuel cuts. I remember seeing a chart for wastegate duty cycle on the uni stage 2 and it was 95% to redline vs Apr like 50%. Hind site I would get APR and go stage 2.
Now I know you can just slap a downpipe on and get an 02 spacer but in another breath I saw that 07GTI-2.0T said the following on a similar thread about APR stage 1 with a DP.
"Stage 2 is tuned leaner. The stock DP restriction causes more heat which requires stage 1 to be tuned richer to cool things down. This not needed on stage 2. Haven't heard this from APR but one would assume if you can go more aggressive on fueling, your probably going to do the same with timing.
3" DP can cause and overboost spike on boost onset if not tuned for it (most noted with GIAC's original FSI tune + 3" DP...when they only had one tune for all stages). stage 2's boost onset is tuned to work in harmony with a 3" DP."
But then also was said was..
"The difference in gain between stock and tuned has little to do with adaptation and mostly the fact that 20lbs of boost (tuned) benefits from a less restrictive DP way more than the same engine and turbo running 11lbs of boost (stock). Throw a DP on a stage 1 car (not tuned for a DP by definition of stage 1) and you've got 97% of what stage 2 has to offer (about 8 less wheel hp than a 230whp stage 2 car..and yes that's based on before and after dynos I've seen stage 1 tune with DP vs same car reflashed with stage 2)
Bottom line is the factory DP is so restrictive with its close coupled 1rst cat and pinched piping directly after an aftermarket DP significantly benefits ANY fsi/tsi stock or otherwise. Don't let tuners " stage" approach make you think our cars don't take to mods without a specific tune for every little bolt on They respond just like bolting on a DP to any other turbo car with restrictive factory DP."
So I'm confused...will it cause problems or not if I put a downpipe on my stage 1 car? :help:
