AJChenMPH
Lt. Commander, USPHS
- Old Bridge, NJ
Okay, I'm going to try to clear up a little of the confusion that I sense going on.
- Rev-matching is simply "blipping" the throttle as you downshift.
- Double-declutching is the added step (during rev-matching) of putting the car in neutral, letting the clutch out before you "blip" the throttle, then pushing the clutch back in and re-engaging in a lower gear. (IMHO, it's not "dumb" even though it's not required in today's cars -- if you're the kind of person that insists on putting in 94 octane gas instead of 91 or 92 octane gas, or putting on Bridgestone S-03's just to cruise around town, then you should learn to double-declutch.)
- Heel/toe is the technique of doing either of the above under braking.
Rev-matching is better than nothing; double-declutching is better than rev-matching. For the most part, today's transmissions can handle the stress of downshifting without either technique in normal, everyday driving. But if you're going to drive your car 10/10ths all the time, or if you're at the track, it's important to at least rev-match to avoid upsetting the balance on your car. The last thing you want under max braking is for the car to jerk as you downshift, and rev-matching helps to avoid that.
