I was curbstoned a 2008 GTI FSI, 99000 mi, looks to be in great shape and have excellent service records. an hour after I grabbed it, CEL came on while getting on the highway. p0299 under boost. No whooshing, wining, or hissing noises, no rough idle, no other codes, mpg seems up to spec. It actually runs smooth, but it does seem a little weak on acceleration (what do I know, I've never had one of these cars. but it doesn't feel like 200 hp). OBDLink, a consumer diagnostic platform for smartphones, can put out a graph showing real-time "calculated" PIDs, including boost. I don't know how accurate this is, but it shows boost slowly creeping up from 6 up to ~9-10 psi at about 6500 rpm at WOT. I can't show the graph, because it doesn't give the option to log anything but the mph for some reason. I don't have the freeze frame at this very moment, but I will if it's necessary.
The three shops I asked had almost immediately jumped to replacement turbo. The one I actually took it into, a gas station service garage near my house, quoted me $2400 for a non-oem kit. I came THIS close | | to having him install a used one from a salvage yard for $1100, but decided against it. Another shop, import garage, quoted for $3200. 4-6 hour job, I'm sure I could get a nice big turbo for $3200, but he's talking about a non-oem -replacement-. This car was exclusively serviced at the dealership during its past life, and in one of the most recent records, the "Turbocharger Bypass Valve" was replaced. I thought they didn't have those, but maybe they're talking about the diverter valve. Anyway, that was 13k mi ago. Wouldn't they have put a better version in? Maybe they botched it?
This is literally my first car. I took a loan out to purchase it. I have no other vehicles to drive for commute. My budget doesn't exactly allow for running about town racking up billable hours and diagnostic fees. I have no tools to work on it. My sought advice would be, what is the most economical way of addressing this issue? Can I run the car for an extended period of time in this state until I can save up for a new turbo? How do I find a mechanic that will actually check for easier fixes thoughtfully before deciding on replacing the turbo? How much should I really be paying to replace a turbo parts and labor? Given the symptoms, is it more likely that it's a wastegate issue? I'm in the greater chicagoland area.
