Jax$MkV
GolfMKV Veteran
- Los Angeles, CA
- 2007 5dr BMP GTI DSG
Thanks man. What do most of you guys do or prefer? Removing the screws or the clip? :iono: Can't the screws be removed with an allen wrench or something?
Is that right side you facing the car or right side (medical right) - as if from the perspective of the car.I read somewhere that it's easier to do one side at a time. Pull up on the right side first and the left side comes out easier. Pull at the places marked by the "X"s. You can pull like hell on the right side but be careful on the left side because it's not as rigid.
Thanks for the write-up! :clap:
Proper rubber grease OK ..A tip: A bit of soapy water on the inside/outside of the grommets can make putting them in the cover and reinstalling it easier.
I read somewhere that it's easier to do one side at a time. Pull up on the right side first and the left side comes out easier. Pull at the places marked by the "X"s. You can pull like hell on the right side but be careful on the left side because it's not as rigid....
