Here is my scan. Vag part number for the core is the E revision. 1k0 963 235 E. I upgraded my canbus a few years ago to a new revision canbus? I was doing the RCD-510 install and changed it so I didn't have the battery drain issues. I've got pictures of the coding as well if you need that.
Monday,03,February,2014,16:58:06:38673
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWEV71K47W249053 License Plate:
Mileage: 195710km-121608mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 55 56 65 7D
VIN: WVWEV71K47W249053 Mileage: 195710km/121608miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Not registered 0001
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
65-Tire Pressure -- Status: Not registered 0001
7D-Aux. Heat -- Status: Malfunction 0010
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6EFD196B7900146E76F-803B
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006908945
Coding: 878D0F214104150047140000001400000028770B5C0001
Shop #: WSC 02609 444 57266
VCID: 6CF913634F1CE67E58B-8039
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 270307 020 0501
Coding: 00038805
Shop #: WSC 02609
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01110100
Fault Priority: 2
Fault Frequency: 31
Reset counter: 18
Mileage: 195605 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4590K10C060261
Coding: E9811F16100212000000
VCID: 69F76A7740EEF35623D-803C
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 56
Mileage: 195605 km
Time Indication: 0
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D7FDE67B4862F760F5-8078
2 Faults Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
End ---------------------------------------------------------------------
