james.bigouette
Officially boring
- Fort Meade, MD
Just thought I would do a quick write up for everyone that has an AEM Dryflow filter on any of their intakes. Mine got dirty really quick so I just went ahead and got some cleaner. Seeing I am snowed in I guess it is a good time to clean what I can. Any questions let me know.
Directions straight from the bottle.
Step:
1. Remove filter from intake pipe and set the filter clamp aside. (If you can't do this step without a picture then you shouldn't be cleaning a filter anyways)
2.Measure the length of the filter media. (I had a stir stick handy)
3. Fill a pail with warm clean water to the depth determined in step 2. Add 1 bottle of AEM filter cleaning solution to the water.
4. Without allowing the solution to flow into the filter neck, submerge the filter into the water and let it soak for 10 minutes. After soaking, rotate the filter back and forth to agitate the water and knock off any loose dirt.
5. Empty the bucket of dirty water (and clean out the dirt!) Repeat steps 3 and 4 with the other bottle.
6. Refill the pail with clean water warm water and rinse by rotating the filter as in step 4. The water should be clear with no signs of dirt in the pail. ( I did step 6 twice just to make sure)
7. Allow the filter to air dry. Do not oil the filter (that's why you bought it didn't you?) Re-install the filter when it is completely dry.
Step:
