U-20T
- Carmel, NY
Used Digital Projection High Light 12000HD - $10,000obo
Super High End HD Projector, working when removed.
Very Bright at 12000 Lumens and HD native - More Specs below
This also will come with Extra lamps I have 2-3 extra lamps for this unit. Lamps are OEM DP lamps that run for $10K oem or $5k+ for aftermarket refurb lamps
More photos upon request
General Aspect Ratio 16:9 (Native), 5:4, 4:3
Brightness (ANSI Lumens) 12000 ANSI Lumens
Contrast Ratio 1800:1
Display Type DarkChip3 DMD
Resolution (Native / Max) HD (2048 x 1080)
Projection Lens Multiple Lenses Available
Size Dimensions (WxHxD) 33.7in. x 16.8in. x 26.7in.
(85.6cm x 42.67cm x 67.82cm)
Weight 185 lbs. (83.91 kg)
Connectivity Inputs G/Y, R/Pr, B/Pb, H/HV, V
RGB
Composite Video
S-video (Y, C)
Component video (Y, Cr, Cb)
Optional DVI input module
Optional SDI / HD-SDI input module
Control USB A Type x 1
USB B Type x 1
RJ-45 x 1
D-Sub 9-pin x 1
Operation Power Supply 200 ~ 240 V / 50 ~ 60 Hz
Power Consumption 2.8KW
Approvals UL60950 FCC Class A
CSA60950 ICES-003 Class A
EN60950 EN55022 Class A
EN55024
EN61000-3-2
EN61000-3-3
EN60950 AS/NZS CISPR.22 Class A
J60950 VCCI Class A
EN60950 CISPR.22 Class A
Audible Noise 52 dB
Operating Temperature 41�F ~ 104�F (5�C ~ 40�C)
Operating Humidity 20 ~ 80% (Non-Condensing)
Storage Temperature -22�F ~ 140�F (-30�C ~ 60�C)
Projection Lens Lamp Type 2.0kW Bulb Type Short Arc Xenon
Lamp Life 1000 hrs
Lens Shift Motorized Horizontal and Vertical Lens Shift
Projection Mode Front, Rear, Front-Ceiling, Rear-Ceiling
Projection Screen Size (Diagonal) 80in. ~ 500in. (203.2cm ~ 1270cm)
Horizonal Keystone Correction Available
Vertical Keystone Correction Available
Brightness Uniformity 80%
Other Dot Clock Single Link : 165MHz Max
Dual Link : 202.5MHz Max
H-Sync Range 15 ~ 105 kHz
V-Sync Range 24 ~ 120 Hz
Menu Languages English, German, French, Italian, Spanish, Swedish, Japanese
Features 10-Bit processing from video input to output
DigiScale - accurate image resizing for faithful reproduction of all displayed sources
DigiView- optimized video processing, deinterlacing and 3:2 pull-down
RGB
Composite Video
S-video (Y, C)
USB B Type x 1
RJ-45 x 1
D-Sub 9-pin x 1
EN55024
EN61000-3-2
EN61000-3-3
J60950 VCCI Class A
Audible Noise 52 dB
Lamp Life 1000 hrs
