Hello everyone,
I have been through a long ordeal with my 2007 gti with the FSI motor and I am hoping maybe someone could help me here. So I was driving the vehicle when I started getting what felt like fuel cuts and the car went into a limp mode. When I got the car home it had no check engine light on but gave a code for low fuel pressure. I cleared the code, but came right back after a short and easy drive. I went ahead and replaced the high pressure fuel sensor on the rail and it ran fine while on a test drive until I went full throttle and got a fuel cut and the car went back into limp mode and shortly after, the car died and would not start. I let the car sit for about ten minutes, then the car started and I babied it home. I ordered another high pressure fuel sensor and a low pressure sensor (the one on the side of the hpfp). The car sat for a week until the parts arrived and before replacing them I attempted to move the car but it would barely run and die almost immediately. I replaced both sensors which didn't fix the issue. I then replaced the hpfp (cam follower and cam lobes were fine) and lpfp, along with the fuel filter. The car still will not start, it cranks and occasionally fires but never seems to catch.
I checked and the timing belt is not broken, every cylinder is getting spark, I did a compression test which was a little concerning: (150,150,120,119). I ended up getting a VCDS cable which has shown that fuel pressure is within the expected range and the injectors seem to be firing (Injection timing displays as 3.57 while cranking), interestingly there are no active codes but I did find that the ignition timing BTDC is at 9.8 while cranking (I am unsure if this is within normal range). My thinking is that the timing belt skipped a tooth or maybe the cam chain broke/stretched? Possibly the engine had a fuel delivery issue and I forked it while driving it? I am not really sure what to check from here or if there is something I can check with VCDS to verify a timing issue when the engine will not start.
Thanks for any advice!
