I had a problem in my car last week, the RPM went high up to 1500~2000rpm and the car didn't move which is clearly DSG slipping then it back again to normal but I feel no torque or power in the low RPM from standstill to ~2000RPM.
I got this fault 19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 004 - - Intermittent
I thought it is time for new clutches.
2 days ago, I was driving the car on D mode for few miles then switched to S mode, after few seconds I got the PRNDS light flashing :frown: the gearbox went in to fail-safe mode when the PRNDS light start to flash and the gearbox remain in fail-safe (limited function) mode until I cycled the ignition again then the car move normally on D mode and I didn't try the S mode.
I did gearbox basic settings successfully and when I was doing the road test the PRNDS light flashing appears again with the fail-safe mode behavior
After reading about the fault it seems it is a Mechatronic issue.
http://wiki.ross-tech.com/wiki/index.php/19143/P2711/010001
I know that VW dealers replace the mechatronic if it is not replaced before or if it is still in warranty but this will never happen here in my country. So, the other way is to get a used DSG gearbox or a used mechatronic only.
I had a plan for AWD swap but the budget is not enough for the time being and no time to park the car until the swap finished, so the swap is not an option now!
I heard that you can reprogram the (TCU) gearbox ECU instead of rebuild it or replace it, but I have no info about that.
I have Revo DSG stage2 and for sure I will lose it once I replace the mechatronic! Another extra cost
Here is the DSG details:
All thoughts and ideas are welcome!
Thx
Thx
