Cat related CEL
MKVail
Vail, CO
When you guys get a cat related CEL, does the coding look like this on VAG-COM? Any help is appreciated. BTW, the Eurosport Cat does not prevent a CEL, for the record.
Thursday,04,September,2008,21:20:07:37937
VCDS Version: Release 805.0
Address 01: Engine
Control Module Part Number: 1K0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0030
Software Coding: 0403010A1C070160
Work Shop Code: WSC 20156
1 Fault Found:
001056 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 4
Mileage: 38436 km
Time Indication: 0
Date: 2000.00.00
Time: 12:34:07
Freeze Frame:
RPM: 1487 /min
Load: 23.1 %
Speed: 39.0 km/h
Temperature: 88.0°C
Temperature: 33.0°C
Absolute Pres.: 760.0 mbar
Voltage: 13.970 V
Readiness: 0000 0000
