did you turn the key to the "on" position then try moving it?
You'd think he could have charged the battery a bit by now . . .
The googles suggest that if you lift the little console around the dsg shifter there is a little yellow lever or button thing "deep in the upper right" which you push to the left w/ finger to release the shifter.
Y just push the yellow tab in and shift the car in gear at the same time. It easy i do it all the time
If its that easy then mine must be faulty. I have even tried moving it with a screwdriver. The whole shifting unit will move side-to-side but it doesn't release.
Which way are u pushing it? You should be pushing it to the left and at the same time move the shifter. It can be tricky, it just easy for me since I do it all the time. I just use my finger
Ok. This is a tough one but I have figured it out. Once you pull open the cover of the shifter you’ll see a yellow piece of plastic at the front of the shifter box. it’s a weird shape you can’t all of it without getting deep in there with a flash light. It has a little prong (which you also can’t see) attached to this little tongue of plastic (all of this is the same piece it’s just shaped weird). With your right hand feel for that little loose end and push that to the left (you won’t feel much if any resistance) and HOLD it there. Then, with your left hand, shift it to whatever gear you want. The key is the little yellow tab, pushing and holding it to the left. That little tab will only travel a half centimeter or so. Not much. Hope this helps. It was a massive pain in the butt figuring this out. CheersI search the manual- nothing. Searched the web- there is talk of pulling up the shift boot and some kind of manual switch you can move to release the lever from park. I can't find it. Anybody know about this?
