cruizin01
- C-bus Ohio
- 07 Rabbit
For you guys that dont follow the Official BT thread.
Had a thread about 3 years ago with a full build but alot has happened since then. Ive since swapped some parts and added some more. Below are the results
I got in contact with Arnold @ pag parts a couple months out of new york. He put together custom kit for me. I had alot of parts already on the car so swapping to newer/bigger parts was a pretty easy upgrade.
powertrain mods
-stock FSI block w/ balance shafts intact
-stock pistons
-stock intake manifold -flappers
-brute connecting rods
-9.5:1 c/r head gasket
-vband stainless exh manifold
-vband turbosmart comp-40 wastegate
-GT3071 with billet wheel upgrade and TIAL vband exh housing
-3.5" mafless intake
-3" catless exh with APR/Corsa CB
-RS4 injectors
-APR upgrade HPFP
-RS4 upgrade fuel pressure relief valve
-custom intank walbro 400
-Labonte stage 3 w/m with dual nozzles
-fluid dampr
-VFE twin intercooler
-Turbosmart E-boost 2 EBC
-Eurodyne Maestro Tuning Suite
Ive got plenty of other suspension/brake and drivetrain mods but I think thats all the important stuff.
Just got the car back up and running a week or so ago on the new software. Havent had to make any adjustments so far except for the warm up enrichment and the cold part throttle is a bit jerky.
Big thumbs up to Brian Turner at DynoTune Motorsports for getting me on the rollers in 2 days notice.
Dyno chart is on 26 psi where I decided to stop. 93 octane plus w/m. I dont have easily switchable timing maps so I decided to keep the race map on the car. I think it would have made high 300's on strictly pump gas.
Overall Im real happy with the numbers. Its more than I expected for the most part. I know its capable of more. >500hp but with stock pistons I dont want to chance a broken ring land with more timing/cylinder pressure. Ill possibly upgrade those at some point If I want more.
Engine bay isn't very pretty but its not a show car. Its a driver.
powertrain mods
-stock pistons
-RS4 injectors
-APR upgrade HPFP
-fluid dampr
