I haven't looked at it in depth yet. I was considering the neck delete, but need to scope it out in depth so I can figure out what kind of cap to use on the reservoir. For the bracket (if I keep the neck) I am considering using the lower bolt (attached to the mount bracket) and placing that one in the fender instead. A little torch, a bit of grinder, some rattle can flat black and a dab of blue locktite and I should be good to go. The neck is obscenely flexible so I don't think it would be in much of a bind moved over 1 -1/2 inches to accomodate the new bracket location. My only other concern when dry fitting is to make sure the hood closes cleanly. Did you cap yours or replace it with a w/m kit? If it something I can pick up the hardware store I would definitely delete the neck! I have topped off that sucker once in a year and a half and only did it because I was filling the wife's car at the time and had some left over.
Eurocars came up with my fix, just removed the filler neck and bought a 1" (i'm not positive on the size, but I'm pretty sure it was 1") threaded PCV cap, and screwed it on. That was it, really simple, and when I need to refill it I just put the filler neck back on to fill it.
