Whitedemon
- Miami, FL
Hi guys, looking for some help/advice.
I’ve been dealing with this issue for a while now, and don’t know what else to do. I have this constant fluid/boost leak at the MAP sensor bung located on the throttle body pipe.
I have a CTS Turbo tb pipe that has a bung for water/meth injection right before the bung for the MAP sensor, here is a picture of the tb pipe:
no matter what o-ring size/material/durometer I try on the map sensor, they all keep failing and I always end up finding water/meth mix all over the pipe. Also tried different types of silicone sealants, Teflon, etc. no luck.
Even went as far as changing the tb pipe with a brand new one(thinking it could’ve been a design defect inside the bung) same results.
My original thought was that the material of the o-ring wasn’t compatible with methanol hence making it swell and expand, but then I tried silicone, viton/fkm, hnbr, etc. they all fail. Also slightly bigger ones (.2-.5mm more of total diameter), some would hold for a few days but eventually fail and leak, especially I noticed after a long drive and maxing out the boost (more spray) this is when it’s most likely to fail.
picture of the mess:
can anyone help with this? This is driving me nuts at this point I just want to get rid of the car if I’m not able to fix this thing…
