Hi guys,
Received my bluefin today.
Installation cannot be completed because when the unit is trying to save the original ECU file an error appears on the unit and it will progress no further.
______________________________________________
-Plug unit in.
-"VW/AUDI/SKODA/SEAT"
-"confirm ign.off and press 'Y'"
-"switch ign. on and press 'Y' do not switch engine on"
-"saving original"........
wait 10-15s..............
-"Error Code D003"
D'oh!
So I had a quick search and it turns out that others have had this problem, and that the problem arises from having had an APR trial previously.
http://www.golfmk5.com/forums/showpost.php?p=1416466&postcount=21
In loose terms, the bluefin map will not write over the other map left on there from the APR trial. (Don't want to get bogged down with why this happens).
Now, I called the place that did the APR trial and the very helpful gentleman has no problems with me coming back to have the stock file 're-installed'. My only problem is that it's well out of my way...
So my question is... does anyone know anywhere else I can go to get the VW stock map 're-installed', other than a dealer, to save me from making the treck up to Mona Vale? I work in Blacktown and live in Eastern suburbs.
Other reason for posting this is to help anyone else who has this problem as the other thread wasn't that easy to find (and took a long time to cut through the technicalities of how / why the bluefin flash couldn't be installed over the APR flash and whose fault it was).
Thanks in advance,
Tom
-Plug unit in.
-"Error Code D003"
D'oh!
Thanks in advance,
Tom
