Blower motor stopped working.
nav922
Yorkshire
MK5 GTI 2007
Morning.
Can anyone shed some light?
Heater blower motor randomly stopped working.
Put 12v to the fan and it spins.
Bought a replacement fan with a new resistor module
Tried different climate control module
Checked all wiring from fan to climate control module to fuse box. All is good and getting 12v.
Checked fuses and relays
2007 GTI
GTI's
MD
You checked these fuses in the dash fuse panel
SC/F22 V2 blower motor
SC/F4
SC/F14
nav922
Yorkshire
MK5 GTI 2007
I’ve checked these fuses and they are all good
GTI's
MD
Is the motor seeing ground at the plug? Do you have access to a scan tool that can scan the Hvac?
nav922
Yorkshire
MK5 GTI 2007
Yeah that’s all good. 12v and ground is good. Got it scanned and was showing - 01273 fresh air blower
But the blower does work
nav922
Yorkshire
MK5 GTI 2007
Yes I’m getting 12v. It doesn’t make sense. Iv tried a new blower motor and new resistor modules. Also blowers work connected to 12v direct
nav922
Yorkshire
MK5 GTI 2007
I believe it’s 2006 but was manufactured 2007 according to my logbook.
Is there anyway of testing the fan control module? Iv tried 3 different ones lol, surely they can’t all be bad
GTI's
MD
If you have a scan tool like Vcds you can look at Hvac module 08 and go to MB(measuring blocks) 007 field 1-4 with 4 being terminal 30 voltage and MB 008 field 1 being term 15 voltage.
nav922
Yorkshire
MK5 GTI 2007
I had a mess around last night again.
I noticed without the resistor module plugged in, we are getting 12v from connector. As soon as everything is plugged back in together it drops down to 1V ? Does this mean that fan control module is bad even though Iv tried 2 different ones
GTI's
MD
At what location are you looking at voltage and seeing it drop from 12 to 1, at the 6 pin plug red/white wire?
