I have a question for those that have installed a DW65v or another pump that uses the stock basket.
Can you feel the port engage with the port on the basket when reassembling?
I did everything per the install guide but I feel something is not sealing. I'm getting fuel starvation at 1/4 tank but it re-primes and runs just fine.
I am in for the same issue for the first time, I have the same on my Rocco. I installed it on two cars before without any problems but unfortunately it happened with me :thumbdown:
The car isn't starting normally and take few seconds in order to have the ignition started, then I got low pressure fault.
Here are the pics and videos.
This video when starting the ignition and the car was parked for 2 days.
https://vimeo.com/171534762
This one the car was parked for few hours!
https://vimeo.com/171534945
Some times it took more than this few seconds and the RPM become hesitated going above and below the 1000RPM for few seconds then it become stable and I got the same low pressure fault too.
I guess I have to check the pump and sealing and everything again :iono:
Any ideas?!
