Audi A1 by mgpdoc ••
mgpdoc
Greece
So many many things have happened while Photobucker has been letting us down, and I havent posted updates ever since. But, I decided I must keep this going on, cant afford to lose all this after all these year.
So, first I did a proper engine bay wash
Some befores
Engine bay wash by mgpdoc, on Flickr
And some afters
Washing engine bay by mgpdoc, on Flickr
And here is the location that some things will change.
Dpf by mgpdoc, on Flickr
But all that in the next post.
Cheers for now.
mgpdoc
Greece
Some weeks ago I ordered and received the Dpf delete 2,5 inch Downpipe from Darkside Developments. Quality was great as you will see yourselves in the picture.
Darkside De-Dpf Downpipe by mgpdoc, on Flickr
Also bought some EGR blanks
Adapter for the lambda senson which is the only one that will be re-used
Next posts will be about installing it and much much more to bring you up to date
Cheers
mgpdoc
Greece
So, this is the place we will be working on for this post. This, and the EGR system.
Here's an idea of the crap that goes inside your inlet on a diesel car with just 28k miles on the clock. Sad is it not ?
De-Dpf exhaust install by mgpdoc, on Flickr
Block of plate to the rescue
EGT sensors off
Lamda Sensor off
After A LOT of fiddling and swearing, the downpipe came off
Not in piece sadly as for this to happen probably all the subframe would have to come off so ef it.
First test fit
TB block off plate - will change to matching bolts later
Downpipe path
Here is where it got tricky will get to that later
Final dp part which is modified with a v band to match the rest of my 3inch cat(what cat lol)back
This is the part where we had clearance issues. Downpipe touched the steering rack. Ofcourse, once again, bolt on fitment wasnt the case
So out again to modify it
Reshaped it and it was great afterwards
Matching bolts as promised
Sensor on
These however had to be left plugged and tucked in place, cause the car cannot work without them. Even after the ecu remap. Will see if maybe at a later version.
This map sensor of the DPF was removed though
Untitled by mgpdoc, on Flickr
Egr and boost pipe removal by mgpdoc, on Flickr
As was this EGR part from the Exhaust manifold to the EGR
Car was a little rolling-coal happy
But nothing a wash and wax cant fix
Then i decided to remove the complete EGR assembly as it was no longer used, to save weight and clean the engine bay even more
Oil return line has to be removed
And you have to make a U-joint for the water pipes that run to the coolant radiator of the EGR which is also removed. Luckily i had the U-joint from the A4 hehe
Blocked this hole as well
And this is what was removed
Then, we remapped the car, it made another 10hp but we havent finished yet, will get back to you with more results once we fine tune it
Big shoutout to etuners greece, and Stelios Alexandrakis in particular.
Cheers
More to come​
mgpdoc
Greece
So another task I have been wanting to address, is the tailights after i removed the paing from the hazard and reverse lights.
Instead I sourced some red tint film like i said i would
Made a template of the area i wanted to cover
Came out awesome with the slightest effort
And still is in place perfectly after much washing, dust, and abuse
Stay tuned, more to come
Cheers
Mike ( @mgpdoc over at instagram )​
mgpdoc
Greece
So, truth be told i was pushing my luck somewhat
In the past i entered the sea with the Cherokee pretty ofter at this particular spot. However . . .
This is not a Jeep
Got pulled out by a family car, but not without my pride and my car being hurt as well. AC radiator got pushed by the bad Darkside IC installation probably, and also, wheels were scratched from the rocks at the beach.
Had no Ac for the next days, and scratched wheels, oh well
On my way back home, at a highway parking
Got back to Athens, and lost no time
First AC radiator replacement, and new mounting points and brackets for the IC, properly this time, and not like my half-ass job on a bad product
All done and I love how the new BEHR Ac Radiator is silver instead of black
Looks mean
Temporary Audi wheels while mine were sent to be painted
Gave it a proper wash
Do these wheels make it look like a Renault or is it just me
I also ordered this Powerflex mount - Diesel Specific - To reduce engine movement which was getting frustrating especially after the track visit.
It increased vibration, but reduced movement like it should
Powerflex by mgpdoc, on Flickr
Oem
And then wheels were ready
I opted for a change to see how it would look. I normally like to keep my cars in a two tone theme. And this is no exception, it was red and black.
However, i thought I'd give it a go on something rather different.
So. . .
Gunmetal Wheels by mgpdoc, on Flickr
This is what I came up with
First time on the car
Gunmetal by mgpdoc, on Flickr
They sure look bigger
To be honest at first i couldnt get used to it but the more i saw it the more i liked it
Threw on some Rota caps in Gunmetal which I ordered from UK again
And the box as well
Summer by mgpdoc, on Flickr
Car is currently away on vacation mode, seeing some dusty roads and beaches
Cheers
Mike​
mgpdoc
Greece
For those who are interested and use Chrome there is a browser extension that you can add in that will allow you to see the photos behind the paywall.
HERE
Just add it in, clear your cache and it should work.
mgpdoc
Greece
Some more updates then to try and bring you up to date, since my lack of time is bigger than ever due to my job.
Some shots after i washed the car on early september
Befores
Post summer wash by mgpdoc, on Flickr
And Afters
I loved it
but, the shade of gunmetal i think quite the perfect one. I just couldnt get it out of my head. to be honest
Car agreed
So, again, onto temporary Audi wheels to get my wheels repainted in the correct shade of gunmetal
Re-Refurb by mgpdoc, on Flickr
Car was looking funny once again
Also bought me a new KArcher machinery
Octoberfest by mgpdoc, on Flickr
Gave my engine bay a good clean, as well as my mate's S3
Results
Next post we are gonna see how the wheels turned out and many many more things
Cheers​
mgpdoc
Greece
Wheels were then ready
Boom
Now we are talking
Red caps and gold letters were an idea that came to my head this time
Came out awesome although the painting on caps coulda been better in my eyes. Wheel powdercoating was perfect
Threw them on the car
In my opinion, best look of the car so far
Cheers, hope you like them
Gunmetal by mgpdoc, on Flickr​
mgpdoc
Greece
Another thing i ordered is some proper Recaro Subframe seatmounts for my car, since the ones i had were Recaro again, but for an Audi R8 it seems.
Proper quality as always
Installing the mounts is a bit tricky. You need to unbolt some framing off the oem seats, and u use it in between the chassis and the Recaro frames. As always pics will do the talking. I used completely new hardware everywhere and blue loctite to be safe like i have done in the past in my other cars
Part from oem seat needed, practically the slider
Seat mount and pads by mgpdoc, on Flickr
Start combining the two
Remove old Recaro mounts
Clean canvas
Test fitting the new ones
New bolts on side frames
And ready to test fit
Dont forget
Looking much better and much safer
The car also had its programmed maintenance schedule
Oil, Oil Filter
Front and rear pads although they did not need to be changed
Wish I had the time to install the Porsche calipers someday though....
And also made some more orders
But more on that, on the next post​
mgpdoc
Greece
So i ordered and installed a KN specific kit for my car
November by mgpdoc, on Flickr
Started like this
Removed my oem box
Old filter
New filter and housing assembly
All back in place
Also, i mounted my fire extinguiher in the rear seat
Came out clean like i wanted it
Uploading more pics as we speak . . .
mgpdoc
Greece
So lets see some progress. . . .
Fabricated some custom spacers of 20mm for the 5x100 pcd
Updates by mgpdoc, on Flickr
I already run 15mm on summer wheels, but wanted another set of 20mm spacers for my winter set of wheels . . .
Threw the ski box on, in time for winter season
My other project was also there seeing the progress fealing jealous
Then I had some more parts trimmed
I love how they came out
mgpdoc
Greece
Then, I started removing stuff . . .
Had some trouble removing the radio main unit - needed some metallic specific tools to pull it out . . . however i came up with this that i broke of a pen, hehe
All done
Also removed the main tunnel console for further changes
Pile of parts got bigger and bigger
Resulting in this going out and.....yeah you guessed it, it will be retrimmed . . .
Also, I managed to source some gunmetal 19mm plastic caps for the lug nuts
Much better
And also modified the audi tool i have for taking them out- shortened it to be able to get in there
Then I decided to work on the bumper, and make the loom retrofit to activate the rear parking sensors which i was a bit bored to do
We did the whole retrofit however, we did not manage to activate the optical thing on the MMI
I hope we manage to at ome point, cause i love that. I now just have the audio warning, with the music volume going down and all, but not the visual thing
Had another roadtrip on the countryside
Ofcourse, having the dashboard apart like this, was an opportunity i couldnt pass on. I had the chance of changing all the interior light in clear white, instead of red, like on all the new audis.
So, time for that, not easy, i can tell you. You have to take out all of the door cards for instance, just for one window switch, etc etc. . . .
While i was there, we retrofitted a new dome light with leds from factory that i had for some time now, and also ordered a new one for the rear "seats".
pics to follow
OEM one out, and rewiring ready to be done
WhiteLed by mgpdoc, on Flickr
I removed all 4 door cards
Various parts where switches and lights are hidden
We also changed from red leds to white on the new dome light
mgpdoc
Greece
This was the hardest to dissasembly
UpDates by mgpdoc, on Flickr
Now that's what i like
Oem leds and reading lights
Ambient light changed from red to white
Bluetooth microphones wired as well
Ordered this for the rear
Will put everything together when the dashboard is ready from the trim shop and will take nice pics :)
More updates to follow, uploading them as we speak
Cheers
mgpdoc
Greece
Finally, i have another interesting update, which i personally enjoyed A LOT
So, this is, or at least was till last year, winter setup on the oem 17s, painted gloss black
Summer wheels were removed and will be washed and polished and stored next to my Golf till next season
Winter 20mm spacers, vs Summer 15mm spacers in the back
What for , you will ask. And I shall reply. For a new set of wheels
i can remember myself wanting these wheels since i was a child, and i never went ahead with it. Till this Xmas :)
Here they are
D154s by mgpdoc, on Flickr
I have opened many boxes with car parts, but there are few that i was excited like this time. I love these wheels.
Inside the boxes, were also some stickers i custom ordered to spice things up a bit
Rare Rims uk, Rota Dealers, delivered once again
Now that is what i am talking about
Specs are 8,5x17, ET35, 5x100pcd square fitment
the blue beast was once again mad at me
After i threw the stickers on, time to mount them
Spacers on
Test fitting
Dont know if i will be selling these, we shall see
Damn so sexy
Currently running my 215.40.17 Kleber Krisalp IIs, but next seasons i will go for 225.45.17 which can be fitted, and are much cheaper and with no stretch on the 8,5 wheel
Threw them on, and installed center caps as well
First touchdown and i am in love
Threw the lug nut caps, which are a pain in the ass to remove, to say the least, but they look tidy af, so they went on
Fitment with the 215.40s
Went for a quicky shoot jut before rain and snow started, excuse the dirty car
Cheers :D :D
unie01
ohio
Love the car:thumbup:
