Audi A1 by mgpdoc ••
mgpdoc
Greece
Some more updates then
Went to the stealership for the 30k km service.
Yeah, I know, me in the dealership? Weird thing. However I try to go for the scheduled maintenance to keep up with my 5 year warranty.
I buy all the original parts myself prior to the service, and then I get a good discount me being an old customer and all.
So, pics
They were also informed about my ecu upgrades and all, so they didnt risk my rolling coal to go alive, hahaha
New oil, oil filter, diesel fuel filter, air filter, cabin filter, and sump plug were changed. What is more, we also installed my custom sump plug with the integrated oil temp sensor from Defi, so as to install the Oil Temp meter at last, which I have had inactive for some months now waiting for the forthcoming oil change. More on that later.
In order to install the sensor of the meter, I had to run the wiring from under the dashboard to the oil sump. Wanted to do it neat and hidden like the boost gauge lines. So onto the pics of the process
This is where we will begin our installation from
Taking off wipers
Mark this with tape to now wonder where they were afterwards
Remove them with love, might take some time in older cars
Take your time removing this. It can easily brake when plastic goes old
Remove the two visible bolts that hold the wiper motor, just to give it some room to play
Here is the rubber grommet we will use to run through our wiring. Clean and oem style
While you try to install everything, friends take random photos, instead of helping you
Dont tidy up everything yet, do that after you see how much wiring you will be needing till the sump
Lift the car
Removed the tray and here is the installed plug with the sensor
Tucked everything
And then I sorted everything above
We have oil temp :)
Difference from petrol oil temp, is not the range of values, but the speed that oil gets up to temp, almost same time with water. Possible reason for that, is the turbo working all the time in diesel cars, I guess
Washed it properly while I was at it
And gave it some extra love
mgpdoc
Greece
One more thing I'd like to show you is this
There seems to be a gap between the lip and the car's bumper in some places.
You pretty much cant do a lot about it, because you either have to trim the bumper or to shape the cupra lip differently.
However, I thought that I could use some kind of spacer there to make it look better.
These are some biller fuel rail spacers I had in my garage, never used
What if I put them there, and run the screws through them
Let's also paint them black on our custom mobile spray booth, shall we?
All done and installed :)
Thanks for looking, hope you liked it
Cheers
Mike
mgpdoc
Greece
Received a small, yet heavy and pricey box from USA. However not so costly for the quality i saw afterwards.
Some pics
Let's see them separately
A stud kit for the AUD1ESEL
Set of nuts, ball seat
Also bought another set of cone seat nuts, which I ended up using
Also some Lock nuts, one set for each car
Also bought these things here, can anyone guess what they're for ?
Lost no time, and started installing the kit
Before
Went with these, better fitment
HUGE rear brakes
used just a bit of Loctite in each stud
All done
Lots of thread to use, yet not more than needed
All done
Lock nuts installed as well, and looks OEM
I might go for some lug caps in black, in plastic, OEm ones, or aftermarket ones, Not sure if those can clip over the lock nut. We shall see.
Stay tuned, more to come
Cheers
Mike
mgpdoc
Greece
Some more updates then. This update is posted both on the Golf and AUD1ESEL blog, due to them possibly being used on both cars.
Some time ago I sourced and received these beauties.
Damn some people scratching everything
18Z in front, 6 pot
Rears
The calipers, supposedly came with brake pads. However, what you are about to see, will change your mind as to how much stupidity can exist out there.
Thought I'd give them a good clean while on vacation, so as to see their condition more properly
Notice anything weird?
In all their glory
i guess pads for these calipers were costing a bit more, so why not weldo other friction material on there
Anyhow
Real colour appeared
Secret ingredient when cleaning calipers - Cold Corona
This one, also has some damage
Front calipers were also cleaned
Again annoying pics
came out nice
All of them together
So my thoughts are :
-Use all 4 calipers on the Golf, as fronts and rears.
-Use the 6 pots on the Golf as fronts, and leave rears as they are, or install OEM 312 fronts on the rear, and install the 4 pots on the AUD1ESEL as fronts, and likewise, install the A1 fronts on the A1 rear axle.
-Use all 4 calipers on Golf, and buy other 6pots for the A1 as fronts - LoL
Either way, golf will be having the 6pots as fronts, so starting with that, I need to source some stuff.
So
1. Mercedes-Benz GL450 discs, 350x32mm discs
2. Brake Pads
3. 14 to 16 special bolts
4. 65 to 67mm rings
5. Modify brake lines
So far
1. I have found Zimmerman drilled ones to be the most likely to buy
2. Does anyone have any part numbers handy ? I will search though when time comes. Something for everyday use, not like a Ferodo DS2500/3000 I had in the past. Something quiet and effective.
3. Sourced those bolts from JHM as a kit and here they are
4. Sourced the rings needed as well, and here they are
Stay tuned, more to come.
Feel free to send me your suggestions on sourcing parts for this new project, as I am new to brake world, other than my bolt-on 8-pot kit on the blue RS4PRA project.
For faster updates, follow me on instagram, @mgpdoc
Cheers
Mike
zrickety
The Fixer
09 GTI
Which Porsche was the donor? Those pads are a joke but calipers look great. Can't wait to see them on the car!
mgpdoc
Greece
So when it comes to tyre fitment, i am one of those type of guys that like this style, for many reasons.
However, in my A1, I had to go for stretch fitment to fit the wheels I bought for it. And although I didnt have any problems so far, 31000 kms on the clock, I still wanted to set the car up exactly like I wanted it to, and that is with some meat on the tyres.
So, in numbers, go from 215.35.18 to 225.40.18, which not only will allow for better cornering, easier ride, harder to scratch wheels, but will also allow for a lower cost on new tyres, and it is also a size i have been using for some time on other cars, and allows for play between cars.
Of course, being bigger in diameter, car will be slower with the same hp numbers, and of course, less fuel efficient.
So let's see what i did
Attempt #1
Changed tyres in the height i was running before
Went with Pirelli's I had from my Golf
Sadly car wouldnt do even a spin around the shop, so changed just the rear ones and left the stretched ones in front till i come up with a solution
RWD Drag Setup for the win #not
LoL
Attempt #2
Thought I'd raise the suspension 10mm in the front
It seemed much more doable this time
Had to test the car on the road with two people inside to see if and how badly it would rub. It looked really good
Attempt #3
Went back to the shop for some final adjustments and with the roller fender ready to chime in if need be
The wheels were rubbing mostly on the passenger side
Here I could see where the problem was
And took drastic measures this time
Cut off the little metallic tabs that cause the problem, and afterwards painted them with colour to avoid corrosion or rust
Same at the back
Car was ready
And went up for an alignment
All done
Really happy with its new looks and mostly its new driving characteristics.
Everyone said it couldnt be done, 225.40.18s on a 9,5x18 ET23 (with the spacers added), but hey, I say, it is doable, on a daily basis, and what is more, I load this car for travelling.
Cheers
Mike​
zrickety
The Fixer
09 GTI
I'm a little sad you went stretch over that meaty setup but it still looks pretty mean.
mgpdoc
Greece
Car went up on the dyno, not so much to go for numbers, we pretty much knew were we were, but mostly to fine tune the black smoke a bit
Smoke was like this before
I hope I can find an after video
Car was dynoed with the OEM file and was found out to almost make 115hp, despite it being sold as 105, and then made almost 146 with just the ECU tune. Torque went from 27 to 36kg. Very very happy with the results, on a VERY hot day, with 40oC in Athens.
This car surely makes more than 150hp on the road. I also think it deserves a better IC at some point...hmmmm....
Some more pictures from that day
And the numbers with the ECU tune from E-Tuners. They will also make a presentation of the project on their site
Cheers more to come
Mike​
mgpdoc
Greece
A lot of things have been going on, but havent had the chance to update this thread, so let's do something about that
Parking sensors were in a bad state
Removed them and drove around like this- LOL
Made some custom OEM colour spray
And some clear coat
Painted them and left them to cure
Installed
Also polished the tips just a bit
They came out great
Now, as for that missing lower trim, it was removed some days ago
To get it painted gloss black to match the rest of the car
Came back like this
Came out great
I also installed something nice and OEM on the 12v lighter plug
Sorry for the crappy pic
Then went for some roadtrip
But more on that adventure, later
Cheers, more to come
Mike
mgpdoc
Greece
So, all was going well and strong
Until I decided to stop here
Then tyre pressure check light came on the dash, and is stopped at the next gas station to check what was wrong. No real need for that, front left tyre was loosing air, tried to fix it, but it didnt hold the night
obvisouly tyres were tired and old from my golf, but they were used mostly to see how the 225.40.18 would go. Plans were to change them with new if they would work on the trip. And they did. Except for this fact.
now, given this happened far away from our capital, it was hard to source another 225.40.18 tyre at the time. Luckily, mostly due to my previous trip to Romania, I had bought a space saver emergency wheel, even though the car came with just the quick repair foam kit. So at the time it was a relief I had it with me, and my trip would not be completely destroyed.
Obviously moved a healthy wheel up front, and installed the spare one at the back
Got stance ?
As a doctor, I tried to make things better, but no. At least I smiled :)
Cleaned the injured wheel to carry it on with me
Me being me, car didnt lose a bit, and was fighting hard to reach private greek beaches
Aha, spare parts I thought
but no. I had to get back to Athens, via the national road, with a speed of . . . . 80km (50mph). Cruise control was good for that, but boy, did it make a 3,5 hour trip to a 6h one. An experience I will never forget. Everyone passing me by, but hey I made it
Car was fully loaded inside
Gave it a quick wash and time for new rubber
I have always love these
Yoko parada's 225.40.18, 20th week of 2016 fresh af. Loved them from the golf, and wanted them in this one too
Installed all around
Gave the space saver a good clean
And then sealed it to protect it till next time
It did so well
yeah, whatever
Cheers hope you liked it
Mike @mgpdoc on instagram for faster updates.​
