Long Time Lurker first time poster
No intentions of thread jacking, just wanted to chime in and get some thoughts from you guys. As well as the OP
I too just recently went K04 during APR's last sale and have been suffering with the same issues as the OP for nearly four months. I've also wasted over 2 Grand trying to fix the misfire issues @ WOT.
Mods are pretty similar, 65,000 Miles on the clock
-APR K04 (Software V1.1 Test-Pipe File)
-APR Runner Flap Delete
-APR FMIC
-APR TBE
-APR HPFP
-S3 Injectors
-VWR Intake
-Rev. D Diverter Valve
-NGK PFR7B (Currently Gapped @ .026)
-R8 Coil Packs
-Carbon Cleaning Done during K04 install
-Rev. B Camshaft. "Replaced @ 52,000 Miles under CPO Warranty with OEM HPFP"
Things I've replaced (So Far)
-LPFP
-Brand New APR HPFP "originally rebuilt the OEM one through APR"
-Fuel Filter
-Three Sets of Plugs "Two PFR7B and 1 OEM"
-Two sets of R8 Coil Packs
-MAF
-Two Leak Tests using smoke at two different shops "none were found"
-Battery
-DSG service at the Dealership
The cold start issue, I believe is directly related to the RFD and I'm not sure any amount of tuning can completely get rid of it. In my case cold starts are pretty horrible if the car has sat for a long duration (in cold weather only). It also takes a few cranks sometimes to get her going. I never had this issue during the summer. When logging I get misfires across all 4 cylinders until the car warms up. This happens in stock Mode as well.
Stage 1 @ 40, 00 Miles, Stage 2+ @ 55,000 miles and K04 @ 63,000 miles. The car ran perfectly at each stage with the exception of the camshaft issue which was a minor hiccup. It's never run right since I went K04 with APR. Right after the install I noticed there was a weird partial throttle issue in D mode that felt like small misfires or power loss between 2000-3000rpm where the tach would bounce, there would be some hesitation and then once above 3500rpm everything would be fine. It could easily be replicated and only at partial to mid throttle. WOT was for the most part fine. Then came the misfires at WOT right @ 5500rpm on multiple cylinders. I took it back to the shop that did the install they log it, send them to APR, and it was incorrectly diagnosed as a leak in the stock air box and the gap of the OEM plugs. At the time, I felt confident that issue was resolved until it came back a week later. Driving in D mode simply became unbearable. A TB adaption was recommended, tried multiple times, and showed absolutely no improvement. We then began looking for leaks and none were found.
The interesting part about all of this is that I seemingly don’t get any misfires in S mode at all, I've logged extensively and they’re simply not present. Hence the recommendation from the shop that did the install for a DSG service. Which was a total waste of money BTW.
After wasting 600$ in diagnostic fees I decided to go out on my own. Regapping the plugs to .026 seems to have helped with the partial throttle issue somewhat but it's still there. The Misfires @ WOT still persist and I’ve yet to find any hardware combination that resolves the issue other than putting the car in stock mode. Another thing I’ve noticed is that if I remove the battery for say 30 minutes, switch to 93 or 91 the misfires go away for a few days.
Looking at some of the
recent threads I see this supposed valve spring issue popping up here and there and I’m wondering why this issue seems to be affecting those running APR’s tune “or they seem to be reporting it more often” I was under the impression that the weak valve springs were isolated to some GLI and CC models. Reading threads like
this really have me wondering if this isn’t a software issue.
I do have a UNI shop nearby and I’m seriously considering changing tunes. I’ve haven’t reached out to them yet. I have some concerns regarding how they handle readiness and if they even have a tune for the RFD.
To the OP not sure if he has a DSG if so do you get the misfires in S mode as well?
