Tools Needed:
Install Time:
Roughly 3 hours if you aren’t taking pictures
Procedure:
First of all get your bare essentials…mine are shown below
Get a nice cart to hold your tools, your essentials, and your cool new Wastegate Actuator
Find a really sweet lift for your badass MKV
Remove your battery cover
Loosen the 10mm nut on the negative battery terminal
Push the wire aside
Now loosen the lug bolts with a 17mm socket and ratchet while the car is still on the ground
Remove rim and set aside (notice how I used the battery cover to hold the bolts, it works great for this and all other bolts/nuts in this project)
Now lift the car up in the air to about chest height so you can work on the inner fender
Use a T6 torx to remove all the inner fender screws
Remove the screws that are circled in red
To remove the inner fender, pull it down in the front, and up in the back. Then pull towards you
Remove the brake cooler plastic crap thingy by loosening the screws shown and pulling it downward
Now loosen the screws on the passenger side and the other side (shown in red) to remove the belly pan
Pull the belly pan towards the rear of the car and set aside
Remove the two screws holding the turbo discharge tube in place
Pull the clip out that holds the intercooler inlet hose in place
Use a screwdriver to remove the intercooler inlet hose
Pull the clip out that holds the hose to the turbo outlet
Use a screwdriver to remove the discharge pipe from the turbo outlet
Remove the splashshield (16mm socket and ratchet)
Mark all the axle bolts for future reference and re-assembly
Use a 12pt bit to loosen the axle bolts (you may have to have two big burly men hold the brake on one side and the rim/tire on the other)
Push the axle rearwards and out of your way
Remove the bracket holding on the N75 solenoid (be careful of the vacuum/boost lines)
Use a stubby 10mm wrench to loosen the wastegate arm nut, remove the clip, and then turn the turnbuckle until the arm is free from the door (numbers 2/3)
Use tin snips to remove the one time use clamp on the stock wastegate actuator
Remove the two 10mm bolts that hold the wastegate actuator in place (shown with arrows), you may need a really skinny dude to get his grubby little hands up in there
Remove the wastegate actuator by sliding it towards the passenger side, then swinging the arm 270 degrees around (first vertical, then to the bottom) and pull out the actuator
Compare it to your new wastegate actuator and be amazed by its beauty!
Wiggle the new wastegate actuator in to place in the opposite way you removed the stock one
Reinstall the two bolts holding the wastegate actuator in place (shown with arrows)
Push the vacuum line onto the new nipple and secure with a small hose clamp
Reinstall the N75 solenoid bracket
Now the fun part…hooking the wastegate actuator arm to the wastegate door (sorry no pics, you will have to figure this one out by how I explain it to you because I cant really fit my camera and hand up in there to show you).
First, spin the nut a few inches back on the arm, who cares where it is as long as it isn’t at the drivers side of the arm.
Slide the turnbuckle over to the arm and begin to thread it.
Turn the turnbuckle onto the arm until it is not easy any more (once you get a tiny bit of resistance, stop).
Now, spin the nut back down to the the turnbuckle but stop roughly 0.5mm – 1.0mm from the turnbuckle.
Tighten the turnbuckle to the nuts position and reinstall the clip.
Reinstall the turbo discharge pipe and slide the clips back into place on both sides (turbo outlet and the intercooler inlet side)
Tighten the discharge pipe to the block
Reinstall the axle in the exact manner in which you removed it
Reinstall the splash shield
Reinstall the belly pan
Reinstall the brake cooler plastic thingy (I have no idea what name to give this)
Reinstall the inner fender
Reinstall the rim/tire combo
Set the car on the ground and tighten your lug bolts
Reconnect the negative battery terminal
Reinstall the battery cover
Turn ignition to the on position and let the throttle body align for 30 seconds
Start the car, it should idle normally, if not, check all connections (IC hoses, Wastegate actuator vacuum lines, etc).
Turn on your Vag-Com and go to 01-Engine
Clear codes to reset adaption.
Drive easily for the first 20-50 miles, varying the RPM so the ECU will adapt to different throttle/boost conditions
Drive normally for the next 50 miles, checking the AFR/Boost/EGT’s on occasion.
Enjoy your new wastegate!
