project92raddoslc
- United States
I am one of the smart gents who purchased the Aliexpress 7.5 facelift lights for my mk7 Alltrack. I have the lights installed and working after repinning the DRL harness. I installed a canbus HID kit so I do not have any faults for high/low beam but I do have DRL faults for both sides and a slight pusling. I did a little bit of digging and tried the following:
I tried coding lasttyp 4/5 last night to two different LED settings. I changed from factory setting (allgemeine Gluhlampe 27w, auch H15) to LED Tagfahrlichtmodule Versorgung and this stabilizes the LED DRL but bulb error still present. I then coded to LED Tagfahrlichmodul Signal and it eliminates the bulb error but the LED DRL pulses pretty severely when the low beams are on.
Any other suggestions?
Solved:
Code Leuchte4TFL LB4-Lasttyp 4 to 4-LED Tagfahrlichmodul Signal
Code Leuchte5TFL LB4-Lasttyp 5 to 4-LED Tagfahrlichmodul Signal
Code Leuchte4/5 TFL RB32-Dimmwert AB4/5 from 100 to 127
Solved:
