I have a Vagcom. Here is the scan:
VIN: WVWEV71K38W236165 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K38W236165 Mileage: 207240km-128772miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0001
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H03NO8NY
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 36362F14E4444D2BB8F-8062
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 206993 km
Time Indication: 0
Date: 2000.00.00
Time: 08:28:11
Freeze Frame:
RPM: 1123 /min
Load: 38.4 %
Speed: 0.0 km/h
Temperature: 0.0°C
Temperature: 0.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.605 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 206993 km
Time Indication: 0
Date: 2000.00.00
Time: 08:29:05
Freeze Frame:
RPM: 867 /min
Load: 24.7 %
Speed: 2.0 km/h
Temperature: 8.0°C
Temperature: 1.0°C
Voltage: 14.732 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73B0D600B7B618035F1-8026
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HJ HW: 1K0 820 047 HJ
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000008014832
Coding: 078D8F214004150047140000001400000028770B5C000100000000000000
Shop #: WSC 08284 444 66993
VCID: 71BCDC08CDAA2A13ADD-8024
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 160108 021 0501
Coding: 00038805
Shop #: WSC 08284
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7G0231170
Coding: 0000000
VCID: 33301600F73658039F1-8066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0ACAWB
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C82CD7CEA88C7FB9EB-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME25506036+
Subsystem 3 - Serial number: 6342MSME38012B603
Subsystem 4 - Serial number: 6352QSME4D722665M
Subsystem 5 - Serial number: 6362QSME4D724679U
Subsystem 6 - Serial number: 63727SME126B6A220
Subsystem 7 - Serial number: 63827SME125B041C/
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0100
Coding: 0002022
VCID: 015C8CC8FD0A3A935DD-8054
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 974 A HW: 1K6 920 974 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0H03NO8NY
Coding: 0003203
Shop #: WSC 00000 785 00200
VCID: 323E1304082C510B947-8066
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 140108F2000947
Coding: E9811F060013020000
VCID: 303A190C0620631BE23-8064
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 254
Reset counter: 255
Mileage: 167203 km
Time Indication: 0
Date: 2000.00.00
Time: 01:51:44
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2J3E03
VCID: 7DA4F03881F25E73395-8028
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120A
Coding: 0001077
VCID: 382A212CEE50BB5BAA3-806C
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
01706 - Switch for Mirror-Adjust (E43)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
VCID: 35342818F9424633B15-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C00
VCID: 045285DCE2182FBB76B-8050
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Component: Tuer-SG 006 1207
Coding: 0001076
VCID: 392C2428D55AA25355D-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B2D51CB2B81F3B46B-8020
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 019 0035
Revision: 00019000 Serial number: VWZ5Z7H2204582
Coding: 0040402
VCID: 290CF46825FA12D325D-807C
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
End----(Elapsed Time: 01:08, VBatt start/end: 11.1V/11.1V. VIgn 11.1V)-----
