2008 GTI won't start, engine doesn't try to crank
New Jersey
2008 GTI Tornado Red
With first one key then all keys - When I turn the key I get normal accessory mode (no error lights) but no sounds or actions from the engine. No trying to turn over or anything. First one key seemed to stop working (again, everything else works - I can lock/unlock and put into Accessory mode) so I used the other key and drove around but eventually both keys won't start the car. Almost sounds like a programming or ignition issue. Any ideas?
GTI's
MD
Find someone that can run a complete scan on all car modules.
New Jersey
I have a Vagcom. Here is the scan:
VIN: WVWEV71K38W236165 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K38W236165 Mileage: 207240km-128772miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0001
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H03NO8NY
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 36362F14E4444D2BB8F-8062
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 206993 km
Time Indication: 0
Date: 2000.00.00
Time: 08:28:11
Freeze Frame:
RPM: 1123 /min
Load: 38.4 %
Speed: 0.0 km/h
Temperature: 0.0°C
Temperature: 0.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.605 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 206993 km
Time Indication: 0
Date: 2000.00.00
Time: 08:29:05
Freeze Frame:
RPM: 867 /min
Load: 24.7 %
Speed: 2.0 km/h
Temperature: 8.0°C
Temperature: 1.0°C
Voltage: 14.732 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73B0D600B7B618035F1-8026
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HJ HW: 1K0 820 047 HJ
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000008014832
Coding: 078D8F214004150047140000001400000028770B5C000100000000000000
Shop #: WSC 08284 444 66993
VCID: 71BCDC08CDAA2A13ADD-8024
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 160108 021 0501
Coding: 00038805
Shop #: WSC 08284
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7G0231170
Coding: 0000000
VCID: 33301600F73658039F1-8066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0ACAWB
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C82CD7CEA88C7FB9EB-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME25506036+
Subsystem 3 - Serial number: 6342MSME38012B603
Subsystem 4 - Serial number: 6352QSME4D722665M
Subsystem 5 - Serial number: 6362QSME4D724679U
Subsystem 6 - Serial number: 63727SME126B6A220
Subsystem 7 - Serial number: 63827SME125B041C/
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0100
Coding: 0002022
VCID: 015C8CC8FD0A3A935DD-8054
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 974 A HW: 1K6 920 974 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0H03NO8NY
Coding: 0003203
Shop #: WSC 00000 785 00200
VCID: 323E1304082C510B947-8066
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 140108F2000947
Coding: E9811F060013020000
VCID: 303A190C0620631BE23-8064
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 254
Reset counter: 255
Mileage: 167203 km
Time Indication: 0
Date: 2000.00.00
Time: 01:51:44
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2J3E03
VCID: 7DA4F03881F25E73395-8028
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120A
Coding: 0001077
VCID: 382A212CEE50BB5BAA3-806C
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
01706 - Switch for Mirror-Adjust (E43)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
VCID: 35342818F9424633B15-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C00
VCID: 045285DCE2182FBB76B-8050
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Component: Tuer-SG 006 1207
Coding: 0001076
VCID: 392C2428D55AA25355D-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B2D51CB2B81F3B46B-8020
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 019 0035
Revision: 00019000 Serial number: VWZ5Z7H2204582
Coding: 0040402
VCID: 290CF46825FA12D325D-807C
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
End----(Elapsed Time: 01:08, VBatt start/end: 11.1V/11.1V. VIgn 11.1V)-----
kingkhan
Canada
Does the MFD show safe in the bottom right corner when you turn on the ignition? It sounds to me like the car is not recognizing the key anymore for whatever reason and is tripping the immobilizer.
New Jersey
no it doesn't show immobilizer symptoms. In my research, I am hoping the ignition stopped recognizing they key, or the starter motor is bad (some say the wiring corroded to the point of no current getting to the motor). My driveway is very sloped so tough to work on a dead car, might need to get her towed.
GTI's
MD
Unfortunately your scan is pretty clean, the dtc in the engine 01 happened miles before the scan and the frequency was 1. The CAN 19 for Incorrectly Coded module I suspect has something to do with tire pressure 65 Not registered, you could see if CAN 19 has 65 checked on the list.
Not sure if you still have the scan tool but you can look in
25 Immo for what it sees from the key fob in group 001
16 steering wheel group 003 field 1 terminal status ignition switch, 50 is for starter
09 cent. elec. group 007 relay activation, 50 is for starter
group 015 is for the clutch position switch in your case because you have a manual trans off/on
