clockwise33
New York Giants Fanatic
- NJ
Before i start digging into it, anyone want to make a guess?
Friday,10,September,2021,17:02:05:39619
VCDS Version: Release 21.3.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 1K0 907 115 B HW: 1K0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0040
Software Coding: 0403010A18070160
Work Shop Code: WSC 08252 444 57356
VCID: 254A4903EC7BC5A390-8070
6 Faults Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 204125 km
Time Indication: 0
Date: 2000.00.00
Time: 08:00:57
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 45.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.065 V
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 001 - Signal too High - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204125 km
Time Indication: 0
Date: 2000.00.00
Time: 08:03:13
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 52.0°C
Temperature: 42.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.319 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204787 km
Time Indication: 0
Date: 2000.00.00
Time: 22:04:43
Freeze Frame:
RPM: 1467 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 21.0°C
Voltage: 14.351 V
008825 - Leak in Air Intake System
P2279 - 002 - - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204800 km
Time Indication: 0
Date: 2000.00.00
Time: 22:21:25
Freeze Frame:
RPM: 784 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 33.0°C
Voltage: 14.224 V
009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
P2414 - 008 - - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204803 km
Time Indication: 0
Date: 2000.00.00
Time: 02:20:07
Freeze Frame:
RPM: 770 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 54.0°C
Temperature: 30.0°C
Voltage: 14.351 V
009766 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit
P2626 - 004 - Open
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204803 km
Time Indication: 0
Date: 2000.00.00
Time: 04:01:19
Freeze Frame:
RPM: 1486 /min
Load: 11.4 %
Speed: 29.0 km/h
Temperature: 60.0°C
Temperature: 27.0°C
Voltage: 14.351 V
Readiness: 0000 0001
www.Ross-Tech.com
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 204125 km
Time Indication: 0
Date: 2000.00.00
Time: 08:00:57
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 45.0°C
Voltage: 12.065 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204125 km
Time Indication: 0
Date: 2000.00.00
Time: 08:03:13
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 52.0°C
Temperature: 42.0°C
Voltage: 12.319 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204787 km
Time Indication: 0
Date: 2000.00.00
Time: 22:04:43
Freeze Frame:
RPM: 1467 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 21.0°C
Voltage: 14.351 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204800 km
Time Indication: 0
Date: 2000.00.00
Time: 22:21:25
Freeze Frame:
RPM: 784 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 33.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204803 km
Time Indication: 0
Date: 2000.00.00
Time: 02:20:07
Freeze Frame:
RPM: 770 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 54.0°C
Temperature: 30.0°C
Voltage: 14.351 V
P2626 - 004 - Open
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 204803 km
Time Indication: 0
Date: 2000.00.00
Time: 04:01:19
Freeze Frame:
RPM: 1486 /min
Load: 11.4 %
Speed: 29.0 km/h
Temperature: 60.0°C
Temperature: 27.0°C
Voltage: 14.351 V
