2.0t FSI AC delete serpentine belt
silentnoise713
Pa
Eos
Anyone know the belt length for AC delete on a 2007 2.0t FSI? Do I need to removed the ac compressor or can the belt route around with the compressor in place? A schematic would be great. VW has too many engine options to get a clear google-image answer. Thanks!
GTI's
MD
Ac delete belt for FSI VW 06f 903 137 L or 06f903137L
Gates K060374
Bando 6pk950
Ac compressor does not need to be removed.
clockwise33
New York Giants Fanatic
NJ
Gates K060374
Bando 6pk950
Hey, this is pretty cool. With the belt being so easy to swap (5 minutes), it might be worth temporarily swapping in the AC delete belt for track days etc. It would save the compressor from taking the constant high RPM beating, and might provide better throttle response for rev matching for 6MT. Might also be a smart part to carry, in case you're on the road and the compressor seizes and pully fails to shear.
Can you see any possible issues with driving with a perfectly good compressor disconnected from the accessory belt?
silentnoise713
Pa
Eos
Gates K060374
Bando 6pk950
Gates K060374
Bando 6pk950
Thanks!
The Gates is 6 rib, 37.4” (or 949mm)
The Bando is 6 rib, 950 mm.
Can look up Gates.com for diagram of OEM belt routing. Diagram does seem to show there is space for the shorted bypass belt to mount with the compressor clutch in place.
Brigand
Newbie
WA
That Gates belt will fit just fine (and presumably the Bando belt too). I've been running it for a little over a year with no issues. Maybe one day I'll replace that seized AC compressor on my car...
