'09 Erratic Front Turn Signals
madkitty
Wisconsin
A month ago I had a "front left turn signal error" appear. So naturally I removed the bulb in question, but it looked to be in good shape. I pulled out the right side bulb to compare which was also in good shape. I put the bulbs back in and tested the blinkers out again and now they both work! I checked the fuse which was also in good shape. About a week goes by and now on my way home from work I get another "front left turn signal error" and before I can pull over I get a "front right turn signal error" as well! I turn the car off and back on again but this time the bulbs still wont work. After getting home I checked the contacts the bulb sits in to make sure there was no corrosion as well as the wires at the socket and everything seems fine. Now this week I have been driving to and from work with some days where one bulb or the other is out or even both. Some days both are on without problem all day. I'm assuming now that it may be a relay but upon doing some research I only came across the Hazard warning switch as being the relay for my indicator bulbs? I don't know if I should replace this now or if I'm just stabbing in the dark at this point.
TLDR:
2009 GTI with Erratic front turn signals. Sometimes both, sometimes one or the other go out and back on. Checked fuse, contacts, bulbs. Is my next step the Hazard warning switch??
madkitty
Wisconsin
I've scanned my faults. FYI I have winter tires on without TPS in them and installed a RCD330 radio with the canbus adapter for the steering wheel buttons to work. The problems with the bulbs have been happening well before the radio replacement.
Here are my fault codes:
OBDeleven data log
Date: 2019-11-30 14:51
VIN: WVWHV71K09W149306
Car: Volkswagen Golf GTI
Year: 2009
Body type: 5-dr hatchback
Engine: CCTA 147 kW (200 HP) 2.0 l
Mileage: 146480 KM
01 Engine Control Module 1
System description: 2.0l R4/4V TFSI
Software number: 1K0907115AE
Software version: 0030
Hardware number: 1K0907115AA
Serial number: VWX7Z0H93NR8JQ
Long coding: 0403010A1C070160
Trouble codes:
No trouble codes found
02 Transmission Control Module
System description: GSG DSG AG6 431
Software number: 02E300051R
Software version: 1942
Hardware number: 02E927770AJ
Hardware version: E10
Serial number: 00000809191600
Coding: 0000020
Trouble codes:
03 Brakes 1
System description: ESP MK60EC1
Software number: 1K0907379AP
Software version: 0107
Hardware number: 1K0907379AP
Hardware version: H45
Long coding: 113B600D49260003880E06E4921F0041B100
Trouble codes:
04 Steering Angle Sender
Trouble codes:
08 Air Conditioning
System description: Climatic PQ35 142
Software number: 1K0820047JM
Software version: 1212
Hardware number: 1K0820047JM
Serial number: 00000000000000
Trouble codes:
09 Central Electrics
System description: Bordnetz-SG H54
Software number: 3C8937049E
Software version: 2602
Hardware number: 3C8937049E
Hardware version: 063
Serial number: 00000009005618
Long coding: 178D8F214004156447140000001400000029770B5C000100000000000000
Subsystems:
System description: Wischer 171008 021
Software number: 1K1955119E
Software version: 0501
Coding: 0038805
Trouble codes:
01493 - Left front turn signal bulb Electrical error in circuit
Intermittent
01497 - Right front turn signal bulb Electrical error in circuit
static
0F Radio Tuner - Digital
System description: SDAR SIRIUS H07
Software number: 8E0035593M
Software version: 0150
Hardware number: 8E0035593M
Serial number: AUZ4Z7H0411558
Coding: 0000100
Trouble codes:
02635 - Tuner not enabled/activated
static
15 Airbag
System description: 6K AIRBAG VW8R 034
Software number: 1K0909605AB
Software version: 8000
Hardware number: 1K0909605AB
Hardware version: 003
Serial number: 003B6D0BV0F4
Coding: 0013899
Subsystems:
System description: BF-Gewichtsens. 007
Software number: 1K0959339G
Software version: 0007
Trouble codes:
16 Steering Column Electronics
System description: J0527 051
Software number: 1K0953549BG
Software version: 0101
Hardware number: 1K0953549BG
Coding: 0012122
Subsystems:
System description: E0221 002
Software number: XXXXXXXXXXX
Software version: 0010
Trouble codes:
17 Dash Board
System description: KOMBIINSTRUMENT VDD
Software number: 1K6920974H
Software version: 2416
Hardware number: 1K6920974H
Hardware version: 000
Coding: 0007203
Trouble codes:
19 Gateway
System description: J533__Gateway H16
Software number: 1K0907530Q
Software version: 0202
Hardware number: 1K0907951
Serial number: 2700K08A1107BF
Long coding: ED817F060013020102
Trouble codes:
01044 - Control module incorrectly coded
static
1C Vehicle Position Detection
System description: Kompass 001
Software number: 1K6919879
Software version: 0003
Hardware number: 1K6919879
Serial number: 1225223T4FBX03
Trouble codes:
25 Immobilizer
System description: IMMO VDD
Trouble codes:
42 Door Electronics Driver Side
System description: Tuer-SG 006
Software number: 1K0959701M
Software version: 1219
Hardware number: 1K0959701M
Coding: 0001205
Trouble codes:
44 Steering Assistance
System description: EPS_ZFLS Kl.074 H08
Software number: 1K1909144M
Software version: 1901
Trouble codes:
46 Central Module Comfort System
System description: KSG PQ35 RDK 052
Software number: 1K0959433CT
Software version: 0221
Hardware number: 1K0959433CT
Hardware version: 008
Long coding: 139006885103281B0904058FB0080F0488DC00
Subsystems:
System description: Sounder n.mounted
System description: NGS n.mounted
System description: IRUE n.mounted
Trouble codes:
52 Door Electronics Passenger Side
Software number: 1K0959702M
Hardware number: 1K0959702M
Coding: 0001204
Trouble codes:
00110 - Mirror turn signal bulb, frt. pass. side Electrical error in circuit
Intermittent
55 Headlight Regulation
System description: Dynamische LWR
Software number: 1T0907357
Coding: 0000003
Trouble codes:
56 Radio
System description: Radio
Software number: 6RD035187B
Software version: 5522
Hardware number: 6RD035187B
Hardware version: 541
Serial number: VWZZZ4K6209876
Long coding: 16000440040005
Trouble codes:
01317 - Instrument cluster control module No signal/communication
static
02873 - Rearview camera system control module No signal/communication
static
62 Door Electronics Rear Left
Software number: 1K0959703K
Software version: 1302
Hardware number: 1K0959703K
Coding: 0001168
Trouble codes:
65 Tire Pressure Monitoring 1
System description: RDK
Software version: 0450
Coding: 0100101
Trouble codes:
01521 - Tire pressure sensor No signal/communication
static
72 Door Electronics Rear Right
Software number: 1K0959704K
Hardware number: 1K0959704K
Coding: 0001168
Trouble codes:
