'07 K04 GTI Misfires
BurgerGuy
Charlotte, NC
Ride
GTI
Looking for some insight on this problem as I've been working through it since March. Am running Unitronic Stage 2+ RFD file on my BPY FSI with a ported/polished/ceramic coated K04. No changes to either wheel or wastegate. Since the K04 was installed, I have experience really bad misfires from ~5500RPMs and up when heavy on the throttle. It's so bad the car won't reach redline if you keep on the gas, but it pulls strong until it hits the "wall." Only codes that get thrown are the random/multiple misfires and then individual codes for cylinders 1 and 4. Also, whenever I crank the car up in the morning I can expect anywhere between 7-14 misfires across all cylinders. The car will pitter/putter and eventually crank up. It seems to take longer to get running on colder days.
I have done the following in an attempt to fix this:
  • Replaced and later rotated spark plugs and coil packs. Used R8 coils and the plugs recommended by Unitronic. Plugs gapped to .028. Misfires did not move when rotating
  • Rotated new S3 injectors. Misfires did not move
  • Ran compression test cold/hot. Everything looks good
  • New fuel filter. No change
  • Installed 145 bar FPRV. No change
  • Tested brand new APR HPFP. No change
  • Installed Unitronic intake/DV relocation kit. This helped quite a bit as I was running a BSH TruSeal from way back in the day
  • Installed latest revision rail sensor (06J906051D) and confirmed the sensor on the HPFP is the latest revision
  • Replaced LPFP and control module. Am running LPFP with part #1K0919051DB and controller with part #1K0906093J. This helped a lot, but the misfires are still present
I also ran some logs which the tuner is reviewing. They're attached to the post as a ZIP. Here's the car's setup @ 119k miles:
  • Unitronic intake/DV relocation
  • Rev. G DV with GFB DV+ internals
  • S3 injectors
  • APR IC
  • BSH PCV block off
  • APR HPFP
  • Latest revision MKV GTI LPFP and control module
  • 145 bar FPRV
Pudding
UK
Other than the LPFP dropping to around 3.5 bar at 5500rpm and 99% throttle, everything else looks normal at a quick glance. Pressure only tells half the story as fuel volume isn't recorded, but clearly the LPFP is struggling at that load/rpm.
What spark plugs are you running?
With the cold starts, does cycling the ignition a few times before cranking it over help?
How does the crank/cam correlation look? Block 91 for live phase angle, should be 28KW for actual and specified, and block 93 (iirc) for static correlation, usually between 0 and -3KW. I've seen these numbers drift dramatically when someone gets the cam sprockets a tooth out following a chain replacement. That can cause the symptoms you describe.
BurgerGuy
Charlotte, NC
Ride
GTI
Am running NGK BKR8EIX.
I always turn on to accessory for ~5-10 seconds before turning it over otherwise it takes longer for the engine to start. I will try multiple cycles to see if that helps.
Should I monitor the crank/cam correlation while driving or when starting the engine?
clockwise33
New York Giants Fanatic
NJ
A few things:
When I was battling K04 misfires on my APR tuned K04 setup I tried several different spark plugs and ended up finding that NGK PFR7S8EG gapped to 0.26 worked best, although I still get slight top end hesitation in cold weather. I plan on switching to a UM tune in the near future.
Your MAF readings are really choppy. Try spraying it out with MAF cleaner and, if no change, try doing a pull with it upplugged.
Do you have an upgraded boost sensor in the car? I see you hit 2560mbar a few times. I was under the impression that the stock sensor maxed out at 2550.
BurgerGuy
Charlotte, NC
Ride
GTI
I recently did a throttle body adaptation which greatly improved the pedal and my morning cold starts are down to ~3-4 misfires on random cylinders. Still misfires up top like before, but the overall driveability and power continue to get better which tells me I'm heading in the right direction.
I've ran the car with the MAF unplugged in the past, but the problem didn't change/go away. Was running worse then so will try again and see if MAF cleaner helps any.
No upgraded boost sensor afaik.
carbonduc27
Stockton, CA
Ride
07 CW GTI 4dr Stage2
I had r8 coilpacks from amazon and ended up switching to oem gti coilpacks and that cured my misfire. The r8s never fit tight enough and I think that led to misfires on all cylinders. Once I switched to some coils that seemed to seat much tighter I was all good. Good luck with the troubleshooting.
BurgerGuy
Charlotte, NC
Ride
GTI
Cleaned the MAF yesterday. It's running even smoother now, but issue still there. Will see what happens over the next day or so.
As for coilpacks, I'm using the ones the tuner recommended and the red cap R8 coils seem to work well. At least they don't die as quickly :)
snobrdrdan
former GTI owner
Are they legit/true OEM VW/Audi ones though?
That'll make a difference
snobrdrdan
former GTI owner
There's the problem IMO
The "original equipment" is some knock off crap from ECS, to trick you, not OEM. You have these:
You wanted GENUINE VW/Audi:
Better price here though:
BurgerGuy
Charlotte, NC
Ride
GTI
That's deceptive as hell. Even the questions down below state the brand is "Original Equipment." Will pick up the Genuine VW/Audi coils and see what happens. I swear if this is the root of my problem after all this... 😒
Will add, I had red caps on the car before going K04 and I believe they were the same part as what I'm running now, but I guess those are okay to use on Stage 1/2 applications.
clockwise33
NJ
I bought these a couple years ago thinking they were OEM. When they showed up without VW/Audi logos I called and bitched them out for false advertising and sent them back for a refund. Shame they are still using that "Original Equipment" phrase.
snobrdrdan
former GTI owner
I've seen people have issues with those ones....I still swear by the OEM ones
Let us know what happens
BurgerGuy
Charlotte, NC
Ride
GTI
New coils installed. Revision G made by Eldor. Immediately felt the car idles better and is smoother on power delivery. Misfires in the upper RPMs still happening. Haven't had a chance to get on the highway with her yet. Will try to go for a ride early in the AM.
Wondering if I need new spark plugs after running them so long like this. If not that...what else?
snobrdrdan
former GTI owner
Those are the latest/greatest revision...glad to hear they did something though.
I'm not sure about the misfires (never went K04), but I'm sure it wouldn't hurt to try new plugs too since they're not that expensive and make sure they're gapped right too
Are you due for a carbon cleaning? FSI still needed that to be done, btw
Similar (old) thread with some tips:
BurgerGuy
Charlotte, NC
Ride
GTI
Plugs replaced and gapped to .028 per Unitronic. Issues still present. The misfires are a bit more aggressive with the new plugs. Guessing the car just needs time to get used to them. The old plugs looked pretty decent. Nice golden brown burn color on all four.
Carbon cleaning was done at or around 90-95k miles so I'm probably due again.
