CoNGLoMeRaTeGTi
- TRuCHoLaND Ny
- MKV
what was done to remedy the problem?
3 Faults Found:
004248 - Intake Manifold Tuning Valve Position Sensor (G336): Open or Short to Plus
P1098 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 72509 km
Time Indication: 0
Date: 2000.00.00
Time: 19:29:52
Freeze Frame:
RPM: 790 /min
Load: 31.8 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 57.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.208 V
000291 - Throttle Position Sensor (G69): Signal too High
P0123 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 72510 km
Time Indication: 0
Date: 2000.00.00
Time: 19:33:41
Freeze Frame:
RPM: 4783 /min
Load: 43.9 %
Speed: 65.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Voltage: 13.970 V
000545 - Angle Sensor for Throttle (G188): Implausible Signal
P0221 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Mileage: 72510 km
Time Indication: 0
Date: 2000.00.00
Time: 19:33:41
Freeze Frame:
RPM: 4229 /min
Load: 12.9 %
Speed: 65.0 km/h
Temperature: 87.0°C
Temperature: 43.0°C
Voltage: 13.843 V
Readiness: 0110 0100
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 72509 km
Time Indication: 0
Date: 2000.00.00
Time: 19:29:52
Freeze Frame:
RPM: 790 /min
Load: 31.8 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 57.0°C
Voltage: 13.208 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 72510 km
Time Indication: 0
Date: 2000.00.00
Time: 19:33:41
Freeze Frame:
RPM: 4783 /min
Load: 43.9 %
Speed: 65.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 72510 km
Time Indication: 0
Date: 2000.00.00
Time: 19:33:41
Freeze Frame:
RPM: 4229 /min
Load: 12.9 %
Speed: 65.0 km/h
Temperature: 87.0°C
Temperature: 43.0°C
Voltage: 13.843 V
