simonskerton
- plymouth
right guys my car is lowered on coilovers, and when i last had it aligned the front camber was at -1.25 degrees.
Ive purchased some MK2 audi TT lower control arms which can give an additional half degree negative camber therefore totalling -1.75 degrees camber.
Afriend of mine has a set of the new H2Sport top mounts which are 4 way adjustable to either of the following, 0, -1, -1.5, -2 degrees. however they dont fit the top of his shock absorbers, and he proposed a swap with me.
They are designed to fit std shocks and my coilovers are stil uing the std top mounts so id presume they would fit mine.
Has anybody here got experience with these top mounts, that can shed some light on them?
How easy is it to change them from one setting to another?
Would you reccommend a trade with him for them.
I regularily frequent track days so can make good use of any camber, but im thinking the ability to swap back to a less aggressive setup when not on track is a mega plus point
cheers guys
Sy
cheers guys
Sy
