another from me
this time gear knob replacement. i thought that the mk5 got a pretty crap standard gear knob! love the Gti version but for £150 it doesnt wash well with me.... so i improvised with some "other" OEM options!
first up is push the gear stick into 3rd. helps get a grip under the gaitor:
put your thumb under the front side of the gaitor and pull upwards. yu will feel a lip/gap where yu can put your thumbs between and pull! it helps to have 2 thumbs under but i had to take a pic at the same time
lift the gaitor upwards so yu reveal the little ring at the bottom of the gear knob. squeeze, pull, twist and yank at the ring with a pair of pliers till yu can pull upwards on the gear knob to remove it:
place a screwdriver under the little clip cap and push it upwards. yu may unclip one side and when yu move onto the opposite side fid that yu just keep pivoting it back and forwards so the trick is to wedge something in the already open side to keep it from closing! be as brute as yu want as it can take a fair bit of puishment plus it will be hidden anyways:
now your old gear knob should be free its time to start putting the new one on (in my case its from an Audi A3 with a chrome collar):
place the end of the new gear knob through the hole in the top of the gaitorand slip the new clip cap on half way. position the hole of the gaitor inside such that when yu clip it shut no slipts or ends will be showing from the top. (note: at this point make sure the fatter end of the gaitor surround is at the top of the gear knob so that when yu replace it its facing the correct way):
push the little clip cap down tosecurely grip the gaitor. now replace or use your old metal ring depending on how much yu anihalated it upon removal:
fit the new gear knob and secure it with either the old metal clip or a zip tie. should stop it moving up and down. then lastly clip the surround into place:
now admire your new gear knob
oh and dont forget your wrist bands from previous years shows
as yu can see below there are a million and one OEM and non-OEM options availible and all it takes its a bit time and ingenuity and yu can get anything to fit
first one is a leaher one from a mk4, second up is from an old audi with a color coded UG top plate, second is an old soft leather one from an old audi and the last one is a skoda octavia number
cheers!
cheers!
