POLARBEAR666
- Australia
You can do this mod by just jacking up front tyres quite high.
Get under the car, reach your hand up past the driveshaft on right hand side of the car (drivers side). Just unclip the 2 tabs at the bottom and one at the top that is a bit of a pain to reach but u will get there.
Then you have 2 choices:
1. Just pull the foam out and then reclip the plastic cover in place so nobody would ever know the insulation is gone.
2. Grab a soldering iron or dremel and cut through the plastic cover into 2 bits so you can pull it out through the gap at bottom of the car.
NB: you may need to unclip the one sensor that is hanging in the gap that goes from the gearbox. Just pull on the metal tab it is supported by and it will pop loose from the subframe and you can position it out of the way.
**Do this at your own risk**
