From this write up: http://forums.vwvortex.com/zerothread?id=2213232
It says this:
Drive axle to wheel hub “hex head bolt”t Use new bolt 200 Nm + one half turn (180°)
-Drive axle to wheel hub “12-point bolt”t Use new bolt 70 Nm + quarter turn (90°)
Which is it?? I understand VW switched the head type, but aren't those bolts the same and shouldn't they be torqued to same spec?? I mean bolt diameter, length, thread and pitch doesn't change, only head style, right?
I've got couple new bolts from ECS and they are 12-point head. 200Nm/150ft-lb sounds more reasonable torque for this....but I need to confirm.
Anyone have a Bentley?
It says this:
