dtvburns
Tweek
- Western NY
Brakes: HP+ are inadequate for track days. The S3 rotor and caliper upgrade takes the heat much better than stock.
After a track day the newly painted front calipers will match the color of the back calipers
Tires: Koni challenge take offs have more grip than REO1s and never overheated and got greasy like the REO1s did (the REO1s are a very good street tire). I was faster in the turns because of these tires
Passing faster cars is way fun! Like these that where trailered in on an enclosed semi and maintained by a crew of 5 who brought nitrogen tanks to fill the tires of the GT3s to make them more consistent (slow as all five of them where and the rubber was replaced for new at the end of the first day)
Being passed by a faster car is OK too because, after all the car is faster. This is a sweet GT3 and it will make yours ears bleed when it blows buy you.
Getting a wave by from a WRX STI is made better by the red Ferrari racing glove coming out of the window
KO4 > KO3 I was topping out at 130 on the back straight and 120 front straight this year compared to 120 Back straight and 110 front straight last year with the KO3 (these are indicated speeds from the speedometer, I know they are off but it is a good comparison)
Engine oil does not look the same as DSG oil (DSG oil is gold and clear in color, or so I am told by HPA luckily I have not seen any in person)
When your PVC blows you will not necessarily find oil around the filler cap, the engine being pressurized to 25 psi might find a week gasket and leak out the top back of the engine under the cam housing and all over the trans(not good, getting this fixed Thursday)
The KO4 makes the engine want more fuel and will make you change the rear fuel filter after 10 or so fuel cuts, my first ever check engine light and going into limp mode in an open track session in the esses and causing a yellow flag.
Meat is a good guy and very helpful. I know he is a good guy because he only threatened to steal my bumper.
Bring VAG to track with latest software, or if you were not smart enough to do this go ask Meat for help.
Take videos the first day in case your car starts squirting oil and there is not second day. All I have is this pic
Do not expect a credit for missing the second day from a HPDE event much less a refund
I did have a great time and had a better day than this guy and two others like him
Driving home on $7 dollar a gallon 100 octaine is not more fun than driving home on 93.
