bazzle
- Melbourne, Australia
- MY08 R32 Silver 3dr
New Hawk Ceramic Low Dust.
Front HB538Z.760 D111
Rear HB544Z.628 D1108
Cost Approx $360-$380 from most vendors here in Oz and OS landed.
Fitted front and rears today, not too hard a job. Rears needed a special tool to rotate piston clockwise under pressure so I had to make one or the wheels would still be off it :help:
Installs were something like this.. may not be 100% complete but the gist is there
Fronts were straight forward:
1.Remove wheel (and all the jacking bits etc that go 1st)
2.Undo large flat spring tab.
3.Remove dust covers off rear of slides.
4.Remove 7mm allen bolts
5.Lever caliper body so piston retact slightly allowing old pads to clear edge lip.
6.Slide off pad carrier and remove pads (undo wear indicator if working on left side)
7.Using a G clamp or piston tool retract piston into body a few mm's.
If you have topped up brake fluid before doing this job you may want to suck some fluid out of the reservoir.
8.Smear anti rattle grease on to rear of pads and clip the new pads back into the carrier and piston.
9.Mount carrier back over disk and locate with the 2 x 7mm cap screws.
10.Tighten caps screws and replace covers.
11.Replace large flat spring tab. I held middle and popped each end in with a screw driver and then tapped middle into its slot. Use eye protection as it can spring off.
12.Repace wear indicator plug. I had to graft my old plug onto the new pad as it came with male instead of female socket:frown: I opened rubber boot and soldered the wires and heat shrunk them then rolled boot back over)
Press brake pedal gently a few times until pads seat and peddle comes back up.
Repeat on the other side.
