#1 |
meerkat
![]() Drives: 06' TR GTI(RIP)/09' UG GTI Join Date: Oct 2007
MPG raised suddenly
Was driving to my girl's house, clicked my MFD over to mpg and it was already reading like 25 and going up. Normally driving to her house im lucky i can get around 22-24 so i was wondering if my cars just bugging out.
I ended up getting to her house roughly 15 miles away from my house with it saying 29mpg on the MFD and i was surprised as hell. I havnt done jack shit to the car and was wondering maybe if its because of it getting warmer out. Past few weeks its been in the 40's and 50's and the past few days its got close to 60. would warmer weather cause my mpg to rise that high? im my case like 6 almost 7 mpg? Even on the way home i hit 26 and it had dropped like 5 degrees outside. Even this morning on the way to work, it was in the high 40's i barely hit like 21 for a 7 or so mile ride. On the way back home from work, it still wasnt even as high as tonight. Anyone else notice with warmer temps, higher mpg? |
#2 |
FIA World Rally Car Newbie
![]() Drives: Sliver 2007 GTI Join Date: Jan 2009
did you use 6th gear more than normal?
#3 |
meerkat
I did not change my driving habits at all.. I just let DSG do its thing and drive.. Like a week ago if i got on it and had some fun id see my mpg go down a reasonable chunk. I tried to do the same on the way to her house and it would dip a bit but no where near as usual
#4 |
Rally Car Newbie
![]() Drives: 2008 GTI Join Date: Jul 2008
Yes, warmer air = less dense air so less fuel is injected to mix it. It might also have something to do with the gas in your tank. I know, at least here in Canada, we have winter gas during the cold months which gives us bad mpg.
2008 CW GTI 4-Door 6MT |
#5 |
Formula 5000 Champion
![]() Drives: 335i coupe 6speed Join Date: Feb 2009
something not right. were u on the highway?
if not reset your MFD to 0. then let it start and see if its fixed. caue i get around 23 in the city and 30 on the highway but 29 in the city is very unlikely. i was getting horrible MPG in the winter like around 18-19mpg but now its alot better. but yeah reset your MFD and see what happens |
#6 | |
meerkat
the drive to work ~7miles is a mix of suburban and highway. |
#7 |
that seems normal. i get about the same on the highway
#8 |
![]() Drives: 2008 Jetta Wolfsburg DSG Join Date: Nov 2008
no more winterized fuel. I have felt it too and it is nice!
#9 |
meerkat
idk, it just threw me for a loop because I havnt seen those numbers in soo long. Ever since ive gone stage2 and especially with the catless dp and all the fun i have sometimes it hard to keep over 20mpg. funny thing is, right now im 1/4 of a tank of gas
#10 |
Taka Take OFF
yeah ive been getting good MPG too!, im pretty sure the weather plays a role on this.
#11 |
i was autoxing today and i was getting 21.9 MPG
#12 |
whats good?
warmer weather is coming. ftw!!!
parting out my gti - http://www.golfmkv.com/forums/showthread.php?t=95511 |
#13 |
![]() Drives: MKV GTi Join Date: Apr 2007
It's that vtwin!
Conglomeratejae modded good give you better MPGs |
#14 |
FIA GT Newbie
![]() Drives: BMP GTI Join Date: Apr 2007
That was my guess when my car did the same thing, i was getting 26-27 then after filling up and driving the same route i got 31.
#15 |
xstartxtodayx
![]() Drives: B6 A4 avant, 09 Mini Clubman Join Date: May 2007
A 15 mile trip is not enough to make any conclusions, also that MFD display isn't the most accurate way to determine your mpg. You should calculate your mpg each time you refill your tank, that way you'll get the most accurate calculation and also you'll be consciously keeping tabs on what's "normal" for you and know when something is not quite right. I average between 27-30mpg for every fill up, sometimes a little more sometimes a little less but usually somewhere between there. You're chipped (I'm pretty sure from what I've read/heard) so that will increase your mpg as long as you're not constantly taking advantage of the increased performance (which I've heard is pretty hard not to do).
But judging by what I've heard about you and your driving I'd have to guess that maybe you kept your speed in the double digits for this trip and that's why you increased your mpg
#16 | |
meerkat
I hardly go above 90 (unless im tearing up nicholls road at like 2am lol) and when i drive on the LIE im never going higher than 80. that night i drove to her house, 15 miles back and forth i was probably doing between 70-80 |
#17 |
Keep right except to pass
sounds like the trip average got reset.
08' GTI UG 2.0T 6MT |
#18 |
Tweek
You must not be doing it right
I get 8 to 13 in an AutoX
"Front Wheel Drive is a crime against nature" H&R 26mm anti role bar front 24mm rear, Bilstien PSS9 coilovers, VF motor mounts and dogbone, BSH intake, Potenza RE-01R on OZ Ultraleggera 18s, APR Stealth turbo back exhaust and APR KO4 kit, APR Fuel Pump Snow water/meth injection, Quaife LSD, HPA Saage II DSG, R32 Brakes |
#19 |
lol probably the display was showing the overall since the drive to thei was all highway and it showed getting about 30mpg
#20 |
I gots Vtak
![]() Drives: 05 RioYellow S2000 Join Date: May 2007
Yooo Dan
When I drive on the highway I drive 80 no less and I get 27 mpg I was driving the other day and decided to take my time and go 65. Goin 65 I kept an average 36 mpg . Im driving 65 from now on when im in no rush. Did you change your the way you speed?
Walk on the white line. Brainwashed! Walk on the same side. Play dead! |
#21 |
meerkat
nope, did not change any driving habit...
it was like any normal day. today on a ~10 mile drive to school on nicholls road i couldnt get higher than 21 |
#22 |
Formula 5000 Driver
![]() Drives: 08 CW GTI 12 CW Beetle Turbo Join Date: Feb 2008
i only get around 18 miles in city, even on highway i only get 26 miles top....
Performance: APR Stage 2, APR Turboback, S3 Intercooler, NEUSPEED P-Flo Intake Handling: TT-S Brakes, Bilstein Sports/NEUSPEED Race, APR Rear SwayBar, BSH Endlinks Others: 17" Team Dynamics, BSH Pendulum and Torque Mounts Exterior: OEM LED Tail, Yellow FTP, OEM Euro Fog Light with 3k HID's, Smoked Sidemarkers and Mirrors, Holeless Grill |
| Thread Tools | |
