plac
GTI Master
- SF Bay Area, CA
This was done on my 2009 4 door car, but 2 door is similar if not exact.
Pic #1: You pull the passenger handle piece outwards as shown. You do NOT pull the window switch part up, as done on the drivers side. If a couple of those yellow clip things stay in the handle you pull off reattach them to the main handle before reassembly.
Pic #2: This pic shows the two torx bolts you uncover after removing the handle. These are 2 of the 5 torx bolts you remove for door panel to come off.
Pic #3: This pic shows the front torx bolt you remove, which is found under the tweeter sail panel:
Pic #4: This pic shows the area of the bolts along the bottom of the door panel. My 4 door has two bolts under the bottom. A 2 door would probably have 3 bolts in that location.
After all these bolts are out, you need to pop the door off. The rest are just plastic clips. These are very stiff the first time and it takes some force to pop them off. I grab the door panel, put my foot on the door corner and pull really hard. Once one comes off the rest are a bit easier.
Pic #5: When you have the door off, you will see it attached with 3 items. The 4" midrange speaker harness, the master window switch harness, and the handle pull cable. You can see the top handle cable which has a rubber sheath to prevent rattling.
Pic #6: This shows the master window harness. You unclip the purple lever, swing it down, than harness pulls right out.
Pic #7: Shows what the door panel looks like. Very spacious and empty compared to every other car I have done stereos on. Nice and easy if you are going to mat.
Pic #8: Shows the dynamat applied. This was to cure a tiny vibration and not a serious job at all. I did more than I planned, and this will quell a lot of the vibrations I was hearing.
The drivers side is similar, except the window switch top section is what you remove to get to the 2 center bolts.
