Dan GSR
- NY , Long Island
will it fit? yes
is it optimal? no
is it optimal? no
when you get to the point that you're squeezing 285's on a 7.5" (or even 8" or 8.5") wheel then you're not helping anything. You'll be crowning the tread of the tire and loosing contact patch as well as adding a good deal of useless unsprung mass.
Looks great.
Were you running any camber up front? It looks like the wheel/tire width prevents you from achieving a lower center of gravity but I guess you were going for maximum contact patch instead.
I was running 2.7 deg up front. With the right ride height and camber, as well as the cross suspension stiff springs it allows the 265's to tuck under the fender. I was as low as I can go while running 265/35/18 on a 18x9 wheel, any lower and my fenders would not be to happy.The car gets corner weighted next week before dubs at the beach.
Looks great.
Cross FTW :happyanim:!!! did you order them with a different spring rate and valving? Oh FYI Adrian is no long with JIC. I own the car that JIC R&D the coil overs from. How do you like them so far?
I have kept the stock valving and spring rate. This was the first season with all the major components on the car. I want to get a good feel for the car before I started fine tuning components. I have no major complaints with the suspension. It has performed flawlessly. However, the front dampening can be a bitch at times, and I had to cut the front strut tower mounts so that I have full access to the camber plates (which is more of a vw design flaw). I would def recommend the product.
Oh wow.. how much of it did you cut? do you have any pics? Yea I can imagine how much of a pain it is to adjust anything form the top side
steel racer, hit up the pittsburgh area forums, were having a meet on the 2nd and it would be cool if you came, i've been looking to get into auto X, but know nothing about it yet.
