where to bolt the OEM amp holder??
ktm25089
GREECE
Hi
Just bought one OEM amp holder to fit my BLAUPUNKT THA475 under driver seat.
Here is a picture.
ktm25089
GREECE
and for where are these bolts?To mount the amplifier to the holder?
part number N-909-674-01 socket head bolt with inner multipoint head.
ktm25089
GREECE
found it!!
it was very easy.The carpet has already the openings for the bolts.And the big bolts are wrong part that i buyed.they are for the seats!
ktm25089
GREECE
so here is the installation.
mount the BLAUPUNKT THA475
place the cover and DADADADA!!!!!:happyanim::happyanim:
and one from the sub.
plac
GTI Master
SF Bay Area, CA
Do you have the part number handy for the amp rack? Do the bolts come with it or do you have to order them separately?
ktm25089
GREECE
Nice work!
Did you use the Blaupunkt plug and play wiring adaptor? How did that work? I assume everything else is factory?
Yes,it have two FAKRA connectors to connect one to the stereo and one to the main harness and on the other end have connections to the amplifier.The power is taken from the radio harness with the same wire.It's very easy and very-very plug and play.The amp quality its not the best but its small,stealth and with NO modifications.
You will be glad how the stock speakers will play!!
ktm25089
GREECE
HOLDER FOR AMPLIFIER 1K0035883C
BLACK BRACKET 1K0035933
HEXAGON SOCKET HEAD PANEL BOLT N90817003
EXPANDING NUT N90946001
COVER 1K0971813B (7G8 PURE BEIGE) (9B9 SATIN BLACK)]
the torx bolt and the expanding nut is to bolt the holder to the side body of the car.As you see in the first foto.you will need two bolts and two plastic nuts.
You will need also 2 M6x16 bolts and nuts to bolt the black bracket to the holder.I will tell you to find not hexagonal bolts but something with smaller head for more room for the amplifier to your hardware store.
plac
GTI Master
SF Bay Area, CA
ah thanks. but i do have an amp rack I am building in the trunk now. This will be good info for other people.
