smokey26_02
- MIAMI, FL
The other day when I had the problem with my car it said that I was running to lean.
Yesterday the car went into limp mode 3 minutes after starting it up in the morning. The following is the code that went off. What is the real problem according to this code?
Thursday,29,January,2009,23:14:12:30079
VCDS Version: Release 805.2
Data version: 20090111
Address 01: Engine
Control Module Part Number: 1K0 907 115 H
Component and/or Version: 2.0l R4/4V TFSI 0030
Software Coding: 0403010A1C070160
Work Shop Code: WSC 14133
1 Fault Found:
000136 - Fuel Rail/System Pressure: Too High
P0088 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 43073 km
Time Indication: 0
Date: 2000.00.00
Time: 09:05:41
Freeze Frame:
RPM: 5546 /min
Load: 22.3 %
Speed: 72.0 km/h
Temperature: 47.0°C
Temperature: 20.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Address 01: Engine
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 43073 km
Time Indication: 0
Date: 2000.00.00
Time: 09:05:41
Freeze Frame:
RPM: 5546 /min
Load: 22.3 %
Speed: 72.0 km/h
Temperature: 47.0°C
Temperature: 20.0°C
Voltage: 14.224 V
