Old 01-26-2009, 08:47 PM   #1
itisagoodname
itisagoodname's Avatar
Drives: '08 G37S
Oil residue and vacuum lines
SO my 'oil' catch can doesnt seem to ever catch any oil. All i seem to get is water and gas out of the can. However there is still a ton of oil residue all over the charge piping and intake manifold.
Where else could this oil be coming from?? So we've all seen leaking check valves... has anyone looked into this valve thats right off the intake manifold and crankcase?? Anyone know what function it serves and would it be okay to block it off for a test, or possibly add another check valve as a backup?
itisagoodname is offline   Reply With Quote
Old 01-27-2009, 08:35 AM   #2
ecoterragaia
Touring Car Champion
ecoterragaia's Avatar
Drives: 2006 Toyota Tacoma 4X4
I am not entirely sure of this, but I think that line and check valve are to your vacuum pump. I wouldn't go blocking it off unless you want to lose the vacuum assist for your brakes every time you go into boost.
ecoterragaia is offline   Reply With Quote
Old 01-27-2009, 11:43 AM   #3
Dan GSR
Dan GSR's Avatar
Drives: 06 GTI
Send a message via AIM to Dan GSR
then its doing its job
Dan GSR is offline   Reply With Quote
Old 01-27-2009, 12:44 PM   #4
FliGi7
FIA GT Newbie
Drives: Cars
More like the engine is sealing properly so there's nothing to catch.
You say you have oil in your pipes but did you check and clean them before the catch can to compare it against?
FliGi7 is offline   Reply With Quote
Old 01-27-2009, 01:05 PM   #5
doctorgonzo
Anti-spin doctor
doctorgonzo's Avatar
Drives: 2012 Golf R
That doesn't make any sense for an '06 with a lot of miles.
doctorgonzo is offline   Reply With Quote
Old 01-27-2009, 03:12 PM   #6
itisagoodname
Drives: '08 G37S
Yes, i removed the IC pipes, TB pipe, DV, recirc noise pipe, and adapter to the turbo inlet. Cleaned out all oil residue after stage 1 PCV fix but before i installed the catch can. Since installing, its been a few thousand miles. The DV, TB pipe, and recirc noise pipe are once again covered in oil. I have not pulled the IC pipes yet but will once i finish with the w/m install.
However, when i look at the compressor wheel in the turbo with my borescope, its clean and spotless.
I looked into the intake manifold with the borescope and the intake valves and ports are caked with deposits. Dirty oily gritty sludge and it looks like the valve shafts have tumors or are developing elephantiasis.
There is no blue smoke under WOT though...
Old 01-27-2009, 03:17 PM   #7
itisagoodname
Drives: '08 G37S
Searching.... but....
Has anyone read any posts where the turbo oil seals have failed?
Kinda neat...
http://www.jhdiesel.com/failurechart1.htm
